Coming 5 years old E60
Re: Coming 5 years old E60
rssid;1058010 said:
Replaced/Repaired so far
1.Transmission Flush
2.Boot Damper(Eng Soon)
3.Brake Pads
4.Wipers (Goodyear from USA)
5.Tyres (PSS Top93)
6.Lower Control arms and other various bushings from under carriage.(Mcwell Ventures)
7.Headlight polish(inside) rewired inside
8.M5 Mirrors (Replicas)
9.Battery wire (IBS)
10.Washer Pump
11.Idle tensioner + Belt
Can you share where you did your headlight rewired and cost?
Thank you.
My '09 523i, the on board computer shows low oil level. I top it up with 1 liter 10-40W oil. I would like to know from sifus here, is there such a thing as engine 'drowning' in oil, since we cant check the exact level.
Ask seanskye about oil drowning engine ......
Top up only when the engine oil low warning light asks you to top up (assuming your sensors are working).
Don't top up just because the oil level indicator 'looks' half-empty. Some fucktard workshop did that to my ride over a few visits and when I drained it for servicing there was 10 (yes TEN) liters of EO inside my engine.
And at minimum level - just 1 liter would do within 100km of the warning showing up ......
wow...you oily man sia! haha :lol:
Anyway.. seriously what's the damage in this drowning case?
will oil seeps into the cyclinder since overflowing
Sort of ... the EO will be whipped up by the crankshaft like beating a egg ....... EO becomes all foamy and airy then that will start flowing all over the place ..... building pressure (almost reminds me of coke fizzing out of a pet bottle) while failing to protect the moving parts. If it bust a seal along the way because of the pressure .... you will get the seeping you mention below.
Would rather under fill than over fill .......
Oily man... gotta find oilman not me hor!
RBB is right about the pressure. If you imagine normal oil press as similar to a coke bottle magnified many times, imagine 2.5times the amount of coke in the same magnified bottle. One good stroke, engine up lorry.
That's why I curse and swear at that fucktard workshop!
Hi, my car recently encounters stalling problem when slowing down before coming to a complete stop. Got to restart the engine. For example, when I filter out from side road to the main road, the engine stalled and the car behind honked at me as I frantically tried to restart the car. Anyone got this problem or solution as there is no faulty sign.
SpoiltBrat;1055154 said:
I changed mine with filter and I think that means the cover (or whatever they call that part).
On a separate note:
I encountered engine dying out with the car moving. At first I thought it was steering fault as that appears on the screen. Then it dawns on me that it was the engine dying hence no power steering or active steering (in my case).
Changed to a new battery and all was fine for months. Suspect my In-Car DVR eating up the power. So, new battery all was fine. Then one day we forgot to unplug power to the DVR for one night and saw the power drain message. Not too long later (days later) the engine dying out fault occurred.
Sent to mechanic and they could only see one error and it was some exhaust mechanism. Left the car for one day. They open up something and closed it back as that was not the cause. That action plus some software reset cost me S$XXX. Now without DVR plugged in, the car seems to be working well again.
Anyone encounter something similar?
Happened to me before in my previous ride.......did you see if there are any shadow codes ?
How is your gear box ?
hi, just spent a few $K to do top overhaul for my GB. No faulty signal code? what is shadow code? Sent into WS but they could not diagnosed the fault. Told either to wait for signal fault to show up or upgrade software but no guarantee to cure it.
WS used the autologic ?
3.Brake Pads
5.Tyres (PSS Top93)
10.Washer Pump
Can share where you changed brake pads? My e60 is due for a change and PML quoted $400 over for a pair.
Buy pads from eng soon. Go specialist to change
i bought from eng soon $60 per pair for pads + sensor $25 and labour only 30 bucks .
Of course the workshop is not bmw specialist with no free wifi, free orange juice and free mei mei to see.
Great.....
30bucks for one side or all 4?
christopher ngo;1071405 said:
Front $30, rear $30. It's my friend WS, normally he charge $30 one side, so total $120.
ok la standard price for pads/disc change. Got $30 for all 4 let me know ^^
