We welcome a BMW 318i at Revol Carz Garage or car-servicing today.
A regular service schedule can help keep your car running its best and saving you money (from repairs) in the future.
Good mechanics will explain to you the car servicing phases and they will conduct a systematic multiple points check besides changing the basic engine oil, oil filter and air filters.
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every thirty to forty-five thousand kilometers.
The best guide for the car owners is to refer to the manufacturer’s manual.
Don’t ignore regular preventive maintenance servicing. Discover a small fault before it becomes a major problem that burns a huge hole in your pocket.
When we service your car, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our strict servicing protocol.
We communicate with the car-owner for any worn-out or broken components before replacing them with genuine and quality OEM parts
Our integrity and uncompromising workmanship are important to us in keeping our loyal happy customers coming back.
Please drop by our Revol Carz Garage or on your next oil change. Our competent mechanics are passionate about ensuring your car is safely on the road again.
A BMW 318i was here at Revol Carz Garage for car servicing.
The BMW is lifted for comprehensive car-servicing and maintenance.
All cars serviced and repaired at Revol Carz Garage receive a complimentary car wash and interior vacuuming.
Best Regards,
Revol Carz Garage Management Team
#02-18 AMK Autopoint S568047
Revol Carz Garage Appointment Hotline: 6555 1171
Happy Vesak Day!
Best Regards,
Your car mechanics should check your brake rotors at every major servicing performed on your BMW.
Generally the lifespan of a BMW rotor is 1.5 times that of the brake pads.
Although it is not necessary to replace them altogether, it is prudent to do so because the rotors don't last long enough to completely "skip" a car-servicing cycle.
Inspect your brake rotors for cracks, scoring or pulsation when braking. Visually, the brake rotor may look good but still be worn out.
A good sign that the brake rotors are worn out is finding ridges around the edges.
Not sure if your brake pads and rotors are worn out yet? Don’t hesitate to visit us for an inspection.
Our experienced mechanics are specialized in repairing BMWs and continental cars.
You can reach us at 6555 1171 or SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation
A BMW 116I dropped by to Revol Carz Garage for rear brake rotor replacement.
The vehicle is lifted for under-carriage work and safety inspection.
Worn rear brake rotor waiting for replacement
New rear brake rotor awaiting replacement
Rear brake rotor replacement is in progress.
New rear brake rotor installed and completed professionally
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
Best Regards,
A regular BMW 528i called at Revol Carz Garage for its gearbox mountings replacement and scheduled car-serving.
Car servicing at regular interval is a good preventative maintenance.
A regular service schedule can save you major expensive repairs. Discovering any failing components before they break down, for example, cooling hoses, timing belt, water pumps, and radiator keep you safe.
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every thirty to forty-five thousand kilometers. Refer to your car manufacturer’s manual is the best guide to know your servicing intervals.
When your car is serviced at Revol Carz Garage, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our servicing protocol.
We communicate with the car-owner for any worn-out or broken parts before replacing.
The transmission and engine mountings hold the engine to the car body or to the sub-frame engine cradle.
In order to reduce the engine / transmission vibrations felt inside the vehicle, the mountings are filled with rubber so that is no direct metal to metal contact between the engine and the car body.
Although the engine/transmission mountings need no maintenance, they should be replacement when the rubber part breaks or separates.
The most common symptoms of a failed engine mounting are excessive vibrations and engine noise felt inside the vehicle.
If you have been feeling the discomfort of vibrations in your car, let our experienced and certified mechanics do the diagnosing and mountings replacement for you.
Our integrity and uncompromising workmanship are important to keep our loyal customers coming back.
Feel free to book your next Car Servicing or repair with Revol Carz Garage hotline 6555 1171. Our competent mechanics are passionate about ensuring your car is safely on the road.
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation
A BMW 528i had its gearbox mountings replaced whilst car-servicing at Revol Carz Garage.
The BMW is lifted for servicing and parts replacement.
The worn out engine mountings waiting to be replaced.
New engine mountings awaiting replacement.
Worn gearbox mountings are waiting to be replaced.
New gearbox mountings are awaiting replacement.
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming
Best Regards,
Car servicing at Revol Carz Garage is never simply a quick touch-and-go, oil change and filters affair.
Our standard policy is serving every car arriving at our garage with a comprehensive servicing undergoes meticulous and stringent inspection by our certified professional mechanics.
All oil leakage repair works and rectification repairs works comes with a 6 months warranty to provide car owner with peace of mind.
To find out more information of Revol Carz Garage car servicing packages, Please feel free to drop by our Revol Carz Garage.
Another BMW 320I arriving Revol Carz Garage for car servicing services
Car hoisted up for safety check
Best Regards,
Selamat Hari Raya!
Best Regards,
Engine mountings hold the engine to the car body or to the sub-frame engine cradle.
Typically, the engine and transmission are both bolted together by three or four mountings.
If you are feeling vibrations in your car, it is likely that the engine mountings are due for replacement. You can relax while our professional mechanics do all the diagnosing and mountings replacement for you.
A BMW 523i F10 drove by to Revol Carz Garage for engine and gearbox mounting replacement
The BMW is lifted for parts replacement and repair works.
New gearbox mountings awaiting replacement
All cars serviced or repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior. This is one of our ways to show great appreciation.
Best Regards,
Maintaining the radiator and cooling system so that engine does not overheat is a significant step towards a long engine life.
When a radiator is failing, you will notice the car tends to overheat at high engine speed. Although this is not always pointing to a failing radiator, it is a good place to start your inspection. There may be a crack on the reservoir tank that causes a loss of engine coolant.
Never attempt to open the radiator cap when the engine is hot lest boiling coolant may “explode” on your face. If you are unsure, it is best to call your mechanics.
Our crew at Revol Carz Garage is ready to come to your rescue if you are stranded on the road.
Call our hotline, 6555 1171 and we’ll do the rest, including seeing you safely home.
A radiator was replaced on a BMW 120i at Revol Carz Garage.
The BMW was lifted for part replacement work and undercarriage safety inspection/maintenance.
A brand new radiator awaiting replacement
Best Regards,
The Servo motor sits at the top of the intricate system situated above the cylinder head. The motor turns the eccentric shaft which then pushes the intermediate rock arms, which in turn pushes the valve to open deeper for more power.
When servo motor fails, the following symptoms may occur.
· EML warning is lit.
· Car loses power.
· Heavy fuel consumption.
· Symptoms occurs intermittently (until cut off or car refuses to restart).
· “Valvetronic Servo Motor” faults warning.
· “Essecentric Shaft Sensor” faults warning.
If your car has these symptoms, our certified mechanics and technicians can fix them professionally. Drive up to Revol Carz Garage for a thorough check. We will only proceed with the repair upon your acceptance of our fair, no-obligation quotation.
You may reach us at 6555 1171 or SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation.
A BMW 320iXL arrived at Revol Carz Garage for Servo Motor replacement.
The BMW is lifted for repair works and thereafter, a thorough undercarriage safety inspection.
New servo motor awaiting replacement
New servo motor successfully installed.
Best Regards,
VALVE SEAL REPLACEMENT
If you notice your car blows blue smoke while idling, chances are the valve guide oil seals in your engine have worn out.
Leaking oil is the most common symptom of bad valve seals. Leaks can damage or contribute to failure in the engine. If you find your oil level is low, the first thing is to check the valve cover and oil sump gaskets for signs of leaking seals. The valve seal leak can progressively worsen over time so it is urgent to replace.
VALVE COVER GASKETS
One of the most common places to have an oil leak is the valve cover gaskets. The leak commonly appears in front of the engine or down the exhaust side.
Leak from the valve cover gasket can create a mess. Engine oil can seep into the spark plug holes and contaminate the ignition coils. Check the valve cover once the gasket has been removed. If you find hairline cracks, you will have to replace the metal valve cover and fasteners too.
If you find your car emitting blue smoke and the valve cover leaking with engine oil, drive up to Revol Carz Garage. Our experienced mechanics check your car professionally.
We will proceed to repair upon your approval of your fair quotation.
Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
You may also text us by SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
A BMW 320i dropped by at Revol Carz Garage for valve seals and valve cover gasket replacement
Valve cover gasket replacement in progress.
New valve cover gasket awaiting replacement.
Valve seals replacement in progress.
New valve seal awaiting replacement.
New valve seal and valve cover gasket successfully installed.
Best Regards,
Happy 52nd Singapore National Day to all! May we all, as one people, one Nation, one Singapore, continue to enjoy the fruits of our harmony and prosperity. Let’s celebrate with the Nation!
Best Regards,
If you have been feeling the discomfort of vibrations in your car, the engine mountings are due for replacement. You can relax while our professional team does the diagnosing and replacement for you.
A BMW 520i dropped by to Revol Carz Garage for engine and gearbox mounting replacement.
The BMW is lifted for mountings replacement work and undercarriage safety inspection.
Engine mountings awaiting replacement.
Gearbox mountings awaiting replacement.
New gearbox mountings awaiting replacement.
Best Regards,
Most modern cars come with power windows. The window regulator is powered by an electric motor. The mechanism that moves the window glass up and down is the window regulator.
A window regulator does not require any maintenance. However, when it fails, the failed part or the whole unit needs to be replaced.
Symptoms of a failed window regulator
- Abnormal noise when a window moves up or down.
- The window falls out inside the door.
- The window rise slowly or jam.
- The window slides up or down crooked.
- The window jammed when the switch is pressed.
The problems must be properly diagnosed before deciding on repair options. Have your mechanic take the door cover off to check the electric circuit and find out which part has failed.
If any of your car windows is problematic, you can turn to Revol Carz Garage. Our certified mechanics will check all your window system professionally.
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Best Regards,
Wishing you and your family a Selamat Hari Raya Haji!
Best Regards,
Maximize the lifespan and value of your vehicle with regular servicing at Revol Carz Garage.
Our fully qualified mechanics can service any make or model vehicle with the latest equipment. We are committed to providing a friendly straight forward comprehensive service.
Our car-servicing packages are designed to meet the varying needs of vehicles, regardless of age and condition.
We recommend a service every six months or 10,000 km and a brake check, clean and adjust for cars with every lubrication service. We will test or inspect fluids, filters and only recommend items that need replacing, saving you time and money in the long run.
Car servicing is all about preventative maintenance.
Be aware of “touch-and-go-car-servicing gimmick” enticed by some scamming workshops. They advertise impressive cheap servicing packages. However, they do a rushed, simple servicing job with oil change (often from bulk) and cheap filter change only. Your safety is paramount.
A BMW 520i arrived at Revol Carz Garage for car servicing.
The BMW is lifted for car-servicing and maintenance.
Best Regards,
Your mechanics should check your brake rotors at every major servicing performed on your BMW.
Although it is not necessary to replace them together, it is prudent to do so because the rotors don't last long enough to completely "skip" a car-servicing cycle.
Our certified mechanics are specialized in repairing BMWs and continental cars.
Another BMW 320i arrives at Revol Carz Garage for brake rotor replacement
The car is lifted for the works.
Brake rotors waiting for replacement.
Front brake rotors awaiting replacement.
Rear brake rotors awaiting replacement.
Best Regards,
Happy Deepavali 2017
Diwali or Deepavali also known as the “festival of lights”, is an ancient Hindu festival celebrated in autumn every year. The festival spiritually signifies the victory of light over darkness, knowledge over ignorance, good over evil, and hope over despair.
Wishing you and your family Happy Deepavali!
Best Regards,
Every time your BMW is scheduled major servicing, have your mechanic check your brake rotors too.
Your mechanic should inspect your brake rotors for cracks, scoring or pulsation when braking. Visually, the brake rotor may look good but still be worn out.
Be aware of touch-and-go gimmicks car-servicing packages offered by some scam workshops. Providing lube from bulk and cheap filters, they do a quick and easy servicing job with only quick oil and filter change and go.
Have you had such a bad servicing experience?
Please drop by our Revol Carz Garage for brake rotor inspection on your next oil change. Our competent mechanics are passionate about ensuring your car is safely on the road again.
A BMW 116i dropped by to Revol Carz Garage for car servicing with rear brake rotor replacement
The BMW is lifted for brake rotor replacement and car-servicing works.
Failed rear brake rotor waiting to be replaced.
New rear brake rotor awaiting replacement.
Best Regards,
Have your mechanic check the coolant expansion spare tank every time you send your car for an oil-change servicing.
When the coolant spare tank ages over time, it becomes brittle and hairline cracks may occur causing coolant to leak before you know it.
The coolant spare tank has a level sensor located at the bottom. If you have low level of coolant warning lit on your dashboard, it is either you have a faulty sensor or coolant leak.
Ignoring it may cause your car engine damage due to overheating.
Do not attempt to remove the spare tank cap while the engine is hot. Extremely hot steam may escape and scald you. Be safe and let your experienced mechanic do inspect your coolant system.
At Revol Carz Garage, our certified mechanics are ready to diagnose your coolant system and only proceed to repair upon your approval of our fair quotation.
A BMW 520i dropped by at Revol Carz Garage for spare expansion tank replacement.
The BMW is lifted for expansion tank replacement work and important under-carriage safety inspection.
Leaked expansion tank waiting to be replaced.
New spare expansion tank awaiting replacement.
Best Regards,
We all know how important it is to maintain our vehicles to ensure long and trouble free motoring
Don't risk damage to your vehicle's engine. A regular service schedule can help keep your car running its best and saving you money (from hefty repairs cost) in the future.
Good mechanics will advise you of potential failing components during the car-servicing checks before your car breaks down.
The best guide for the car owners is to refer to the manufacturer’s manual for the recommended car-servicing intervals.
Don’t ignore regular preventive maintenance servicing. Detect a small fault before it becomes a major problem that burns a huge hole in your pocket.
Be aware of “touch-and-go” car-servicing gimmicks. Some auto-workshops may lure you with cheap service for a quick profit. You may get sub-standard parts and lube (likely from bulk) .
At Revol Carz Garage, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our strict car-servicing protocol
All our work is performed to the highest standard and we use only top quality products that meet or exceed your vehicle manufacturer's specifications
Call our hotline 6555 1171 for an appointment for an Oil Change at Revol Carz Garage.
A BMW 525i XL has her major car-servicing performed at Revol Carz Garage.
At Revol Carz Garage, we perform the highest standard on car-servicing. The vehicle is lifted for careful inspection and maintenance for a safer ride.
Best Regards,
