Can they fit?
Gonzo
Hi all,
Can anyone advice on the following:
1. Can a set of E46 318 cabirolet suspensions fit into a E46 318i sedan? Both are valvetronic models.
2. Can a set of fog lights from the above mentioned cab fit into the above mentioned sedan?
Thanks in advance
Cheers,
Adrian
Re: Can they fit?
Gonzo said:
Hi all,
Thanks in advance
Cheers,
Adrian
1. Yes it can
2. Fog Lights ,that depends on the shape of the foglights , if the same then yes if not then No
As far as I remember, the original foglites fitted onto the cabrio/coupe are different from those of sedan's
Re: Can they fit?
Thanks for the reply TripleM!!!
I'll be looking forward to swap the suspension kit by the end of this mth. Hee hee......
Re: Can they fit?
Cool..
Do note , however, that you ride will be much lower but stiffer as cabrio is rather heavy..
But all shud look good :) and congrats
Re: Can they fit?
yup approx. 2 fingers lower.....
My uncle's ride is exporting. Thus planning to swap.
Now need to source for rims!!!
