BMW New Service Bulletin Information! *IMPORTANT READ*
Azrielsc
Core Group Members
Hello everyone,
Seems like most of us are posting problems rather than solutions so I will buck the trend and post a solution instead! :)
Here is a list of New Technical Service Bulletin (TSB) Information for our cars! (Correct as of May 08). Pulled it off E90post.
Service Bulletins
Bulletin Number Type Date Subject Series
00 10 07 SI May 2008 Key Reader Incorrectly Shows Service Items for Replacement E60, E91, E92, E65, E63, E90, E70, E66, E93, E61, E64
00 01 07 SI May 2008 New Vehicle Preparation and Maintenance Requirements: 2008 E82, E60, E88, E85, E86, E91, E92, E63, E65, E90, E66, E93, E61, E64
01 04 08 SI May 2008 BMW Center Self Review Form All
01 03 08 SI May 2008 OEM Tire Manufacturer Warranty Coverage CD-ROM All
04 13 08 SI May 2008 Universal Transmission Support for Manual and Automatic Transmissions All
04 05 08 SI May 2008 Roof Clamp Set E92
04 04 08 SI May 2008 Door Window Adjustment Tools E82, E83
04 03 08 SI May 2008 New Engine Support Adapters E38, E65, E66
04 09 07 SI May 2008 New Battery Charger - V&H Multicharger 750 All
04 08 05 SI May 2008 Aluminum Body Tools E60, E63, E61, E64
06 05 08 SI May 2008 Service Roundtable: May 2008 Show All
07 05 08 SI May 2008 DIS V54 Changes Based On Diagnosis Feedback (June 2008 Release) All
07 06 07 SI May 2008 Diagnosis Process All
09 02 07 SI May 2008 CCC: Enabling Code (FSC) Required for Voice Recognition System E82, E60, E88, E91, E92, E63, E71, E90, E70, E93, E61, E64
09 05 01 SI May 2008 Programming, Coding, Individualization with Progman E82, E88, E46, E53, E85, E60, E91, E92, E39, E65, E63, E83, E90, E66, E93, E52, E64, E61
11 13 07 SI May 2008 N54 Rattle Noise from Turbocharger Area E60, E92, E90, E93, E61
12 19 08 SI May 2008 S85 - Power Reduction with Idle Actuator Faults Stored E60, E63, E64
12 14 08 SI May 2008 Service Engine Soon Lamp Is Illuminated, EKP FC 2786, 2787, 2788 E92, E90, E93
12 55 06 SI May 2008 N54 - Diagnosis for DME FC 29DC/2FBF E82, E60, E88, E92, E71, E90, E93, E61
12 18 05 SI May 2008 N62 and N62TU Engine Diagnosis Test Plan Updates E60, E53, E65, E63, E70, E66, E64
23 01 08 SI May 2008 TeileClearing for Getrag Manual and SMG Transmissions E82, E60, E88, E46, E85, E63, E92, E91, E90, E93, E64
24 03 08 SI May 2008 E6x, E9x with N54 and 6HP19TU - Jolt and Delay when Pulling Away E60, E92, E90, E93
24 19 07 SI May 2008 Diagnostic for GWS Faults - Drive Position "D" Cannot Be Engaged E60, E61
24 10 07 SI May 2008 The Transmission is in "Failsafe" Mode with EGS Fault CF33 Stored E60, E91, E92, E90, E70, E61, E93
25 02 07 SI May 2008 Diagnostic for GWS Faults - Drive Position "D" Cannot be Engaged E60, E61
28 02 08 SI May 2008 TeileClearing for M DCT Drivelogic (double-clutch) Transmission E92, E90, E93
28 01 08 SI May 2008 M Double-clutch Transmission with Drivelogic Fluid Requirements E92, E93
34 03 08 SI May 2008 Parking Brake Repair Instructions E65, E66
51 13 08 SI May 2008 Rattle from the Armrest Hinge E82, E88
51 07 08 SI May 2008 Rear Windows Inoperative After Junction Box Replacement E93
51 06 08 SI May 2008 Window Short-drop or Anti-trap Malfunctions E82, E88
51 04 08 SI May 2008 RHT Rear Roof Shell Headliner Eliminated E93
54 06 08 SI May 2008 Clicking Noise From Sunroof E70
61 06 08 SI May 2008 Sliding Sunroof, Interior Lights, and Rain Sensor Are Inoperative E71, E70
61 05 08 SI May 2008 Windshield Wiper Parks out of Position E91, E90
61 04 08 SI May 2008 TeileClearing for General Electrical Systems E82, E88, E60, E91, E92, E65, E63, E71, E90, E70, E66, E93, E64, E61
61 13 05 SI May 2008 Dead Battery - Energy Diagnosis Must Be Performed E82, E60, E88, E91, E92, E65, E63, E71, E90, E70, E66, E93, E61, E64
62 01 08 SI May 2008 Cruise Control Display in Instrument Cluster Increments Incorrectly E82, E88
63 05 08 SI May 2008 CC Message Missing/Incorrect when Front Parking Light Faulty E60
63 02 08 SI May 2008 Rear Bulb Failure E92
64 06 07 SI May 2008 Air Conditioning Compressor Does Not Switch On E60, E63, E61, E64
64 21 05 SI May 2008 Troubleshooting Air Conditioning Compressor Noise All
65 11 08 SI May 2008 iPod Classic Is Discharged after an Extended Period of Inactivity E82, E60, E88, E91, E92, E63, E71, E90, E70, E93, E61, E64
65 10 08 SI May 2008 RAD2: Intermittently No Audio after Check Control Message E82, E88, E91, E92, E90, E93
65 01 08 SI May 2008 SIRIUS Radio Stations Missing in "All Channels" List E82, E60, E88, E91, E92, E63, E71, E90, E70, E93, E61, E64
65 08 07 SI May 2008 USB Audio Interface E82, E60, E88, E91, E92, E63, E71, E90, E70, E93, E61, E64
66 05 08 SI May 2008 PDC and Warning Gong Volume Too Low E88
72 01 08 SI May 2008 Passenger Seat Belt Assistant Extends Unexpectedly E92
84 03 08 SI May 2008 Echo and Poor Voice Quality on the Landline Side of a Call E83
84 07 07 SI May 2008 NAD Found to be Faulty when Performing SI B84 22 05 (Reactivation BMW Assist ) E46, E85, E60, E53, E65, E63, E83, E91, E66, E90, E64, E61
84 62 06 SI May 2008 Progman Displays ''The TEL Control Module is Malfunctioning'' on the Final Report E60, E65, E63, E91, E66, E90, E64, E61
84 27 06 SI May 2008 BMW Assist Inactive Warning Message Displayed E46, E85, E60, E53, E65, E63, E83, E91, E66, E90, E64, E61
84 26 06 SI May 2008 Cannot Enable BMW Assist Services E60, E65, E63, E91, E66, E90, E64, E61
84 25 06 SI May 2008 NAD Check, Recovery or Deactivation Procedure (MOST-Bus Vehicles) E60, E65, E63, E91, E66, E90, E64, E61
84 24 06 SI May 2008 NAD Check & Recovery Procedure (I/K-Bus Vehicles) E46, E85, E53, E83
84 15 03 SI May 2008 BMW Assist Initialization E82, E88, E60, E91, E92, E63, E65, E71, E70, E90, E66, E64, E61
The one that I was concerned about is highlighted in RED.
I had 6 blown bulbs in the period of 1 year, that's 1 bulb every 2 mths and it always occurred to my right rear brake lights. So today, when I was out, I decided to turn into PML Alexandra to get another bulb and be on my way.
Once I was there and spoke with the technician, he went over and removed my rear brake light carrier and said that it is a known issue and immediately told me to get a warranty claim on it. He drew out the last piece in stock and replaced my rear brake light carrier.
Drove away within 30mins....
So moral of the story? Know your TSBs to get your warranty claim fast-forwarded.
Sam
Re: BMW New Service Bulletin Information! *IMPORTANT READ*
Nice work Bro!!! thanks a lot!!..........hamz
Azrielsc,
Thanks for the listing.
Err .... if i want to read more about a particular issue on that list, where do i go?
Good question, I guess the best is to search on E90post.com. :)
Hi Sam,
My 320i headlight bulb on the right side is blown. What is the procedure to get PML to change it ? I know it is not covered under warranty and was informed by Steven from PML parts centre to buy the bulb from them at $24+ . After that I can proceed to ask the customer service people to find a technican to change the bulb for me. No advance booking is required.
Is this how you did it previously ?
Thanks.
p9993us;365561 said:
Hi Sam,
Thanks.
That's the best way to do it, but go at off-peak ... late morning or early afternoon ... when CSAs are not so busy. The CSA will not charge you for their effort which can be quite a bit as it is not exactly easy to access the headlight bulb for E90, and also E60.
Whatever it is, dont ask them to do when you send your car in for servicing as they will then have to charge labour which can be on the ridiculous side.
my e92 3rd month blew left one of the rear brake light bulb. 1 month later right side blew. KNN pls tail gate me hor, one fine day all my brake lights may fail at one go.
Hi Sam,
Thanks.
U can also buy it from Eng Soon & DIY. Philips Premium is about $15/pcs. Juz b careful as headlight is plastic parts.
box
One problem with aion gold playing online poker is that you can't see your opponents' faces. Poker is as much about bluffing as it is who has the best hand and thus, being MS Mesos able to read the other players' expressions and body language is a vital part of a winning strategy. But you can't do this in an online game, so you have to rely on other clues, or "tells", as to how strong or weak your Cheap WARHAMMER ONLINE GOLD opponent's hand is. One way you can do this is to use "betting tells" or reading how your opponent bets.There are three types of such tells: how long your opponent takes to make his bet, how much EVE Online ISK he bets, and his use of the 'in-turn' box (used by players playing more than one game at a time). For example, if he pauses before he makes his bet, he may possess a weak hand. If you play with particular opponents EVE ISK long enough, you can detect patterns in their tells that you can exploit.
apparently i also have the experience of right rear break light failure occuring concurrently within a period of 6 months... for both occurance 5 or 6 bulbs (can't really rmb) was changed... hopefully it don't occur again...
Currently driving a 4yrs old BMW325i model, where can i find cheap & good service workshop?
