BMW e60 fuel filter
Algino
Clocking to 130k mileage and wonder should I change the above ? Some said need to change after 100k or it just like what pml always say " lifetime " again ??? Really not idea and hope some one can enlighten me on this .. Thx in advance !
Re: BMW e60 fuel filter
The filter is together with the fuel pump and mount on the tank. Under the rear left passenger seat. I change at 160K because the connector crack and leak petrol. Think if nothing wrong then no need to change.
Hi bro, how would you know your connector has cracked? Will the idrive prompt an error code?
If 1 drive a lot to Malaysia, it is good to change it every 50k km. On the other hand, it is a good practise to change both filter & pump around 100k km or 5 yrs. My previous E39 fuel pump uplorry around 110k km at slightly close to 6 yrs mark.
When it leak, you can smell the strong petrol fume in the car because the it is under the seat. The filter is mount together with the pump. So need to change together.
Not cheap. 400+ include parts and labour.
Mine aso had a hairline crack at d plastic L-shaped pipe.
Mechanic noticed some smell of petrol at the rear under carriage.
Mileage was ard 115k km.
Any site sponsor can do this ..... Check for part availability and then try not to go to the workshop with a full tank of petrol.
robing888;959220 said:
Bro, can pm where you did it? ?
Its seems like my have the same problem
