pandaxiong;774647 said:Go where programme bro? I also want..my have button but not the functions...Cheers.
lim_ck;774655 said:3 options.
1. go to one of the workshops and pay a 4 digit sum for the entire package (hardware and programming). cost is about half from what PML charges for the retrofit
2. buy hardware yourself from stockist/ebay and find a workshop with the proper equipment to do programming for slightly more than $100.
3. buy hardware from stockist and programming cable from ebay. find the necessary software online and do your own programming.
I went with option 3 but so far not successful. radio can pair with my phone and make/receive calls but i'm not able to hear the other party via car speakers. may go to one workshop to try the programming and see if they can make it work. if cannot may mean that my usb/aux in/bluetooth module is defective.
edit: the necessary hardware to add on costs less than $100. but stockists here do not hold the parts so i had to order them through one stockist to be shipped in from germany.
ryan75;774676 said:your nick is familiar, used to drive a mazda 3 and collect absolute vodka bottles?
btw, how much is the bluetooth hardware?
lim_ck;774695 said:Yes. I'm that person.. U r?
I got the hardware for abt 40euros. Still need to buy extra cables n such though which came up to another 10-15 bucks.
So in summary, this retrofit can be done for abt 200 IF u already got the USB/aux in option installed in ur car since the control module is already there.
ryan75;774708 said:Haha... Good to see that you are still DIYing...
I'm Ryan, went by nick Ryan back in the Mazda forum, used to drive a velocity red sedan.
Anyway, I went for the lazy way out by using a belkin aircast bluetooth adaptor to the aux-in. Cheaper at $110, plug and play too.
Belkin CarAudio Connect AUX with Bluetooth F4U037tt
lim_ck;774716 said:sorry, dun ring a bell. may recognise your face if i've met you previously at the meetups though.
my car came with the garmin gps option and technically phone can be connected via the gps unti. however i hardly use the GPS and it's always stowed away in the car. so being able to retrofit a OEM solution and use the steering wheel controls as well as voice commands is more appealing to me.
ryan75;774749 said:That's a long time ago indeed.
yes, OEM solutions that make use of the otherwise white elephant buttons is the most appealing.
so what are you going to DIY next?
lim_ck;777848 said:Finally got the bluetooth and voice commands to work. All in all cost less than $200 to complete this retrofit.![]()
BMWSiao;792321 said:bro, can share how you did it?
lim_ck;792502 said:if your car already comes with the USB/aux in option, the retrofit will cost less than $200.
If not, the cost will be much higher since the bluetooth phone requires the ECU which also provides the USB/Aux in option. this ECU will cost about 600 to 800 from BMW but you can find used ones on ebay for half the price.
Anyway, what's required is the following hardware
microphone - order from stockist (2 to 3 weeks)
bluetooth antenna - order from stockist (2 to 3 weeks)
antenna cable - buy from ebay (2 to 3 weeks)
wiring for mic - buy from sim lim tower
pin connectors for mic wiring - order from online electronic store. BMW uses a specific type of pin connector so using other types from sim lim will not fit properly
programming cable - buy from ebay (if you intend to do programming yourself)
programming software - buying the cable should come with it. can also download online.
I read online that cars in US manufactured before march 2009 will have the mic and antenna wirings already pre-installed. Not sure if this applys for our local models. Anyway the mic and antenna wirings and pin connectors cost less than $20.
once hardware have all arrived, need to run mic wiring from boot to driver side map light compartment and then do the necessary wiring connections to the ECU.
car will need to be programmed as well to add the option code.
the whole installation and programming should take no more than 2 hours to complete. I took a much longer time cos I encountered problems with programming.
Once it's done you will be able to use the steering wheel controls to make calls. however the phone button on the steering wheel only will call the last dialed number. your phone book will also be download to the radio as well and you can browse for the number to call. the radio can store phone profiles for up to 4 different phones.
oh, you can also use voice commands to make calls as well. pressing the voice command button on your steering wheel will activate the function for voice controlled phone dialing. this function is automatically enabled once the programming for bluetooth phone is done. (i wonder how a vendor can quote me 1K just to enable this function when there's no additional programming to be done)
Ma320i;879764 said:Hey, will love to have it on my 2005 e90 . Care to share where can i get this done?
Thanks
gibbon28;888669 said:Hi,
You actually can done it at Soundwerkz. one of the site sponsor.
But need to ensure that your phone is supported. Some Android phone do not support.
