Bluetooth for LCI 5 Series ...
nAuTiLuS^
Hi Guys,
Have been thinking of retrofitting the hands free bluetooth system into my ride but not sure if my Blackberry Curve 8320 can pair with it?? .... Anybody with a similar setup? Can anyone install the bluetooth system other than PML ?? Thanks bros! :)
Re: Bluetooth for LCI 5 Series ...
Wanting to know too.....camping here for expert responses.
Guess no one has a Blackberry linked to his/her Bluetoothed Bimmer? ... ACS6 go try it dude! :yummie:
Just received my company issued BlackBerry 8300 yesterday.
It does pair with the original in-built blue-tooth in my e60. Address book is synchronised, means you can search the address book with the i-drive and the caller id displays on the screen for incoming calls.
Also tested the Blackberry with the Nuvi 610, works perfectly as welln with the Address book synchronised.
Hope this answers your query.
Sweet !! .... Guess i am off to get it installed into my 5er ... dont suppose anyone can do it other than pml ?? :)
They do not have the snap-in kit for the 8300/8320, you can check at Best Sellers BMW Snap in adapters
The full BT installation includes power for charging the phone and RF connector. I use 2 phones. The other is an Ericsson which is only used for long drives into Malaysia, so the phone gets charged in the cradle and at the same time better signal since the RF cable is connected to the GSM antenna on the roof.
Thanks Bala ! Did you do a local retrofit for the Bluetooth at pml or did you get it as a factory install option? Just wondering if it would come with the Voice Control option as well ? Thanks bro! You have been most helpful :)
The option was not available at the time when I ordered my car. PML had it retrofit locally a month after I collected my car. The voice dial works but it can be disappointing, not sure if its due to our local slang. Picks up the wrong names at times or picks out the wrong digits. Its not really practical, easier to shift through the I-Drive and pick-out the name and dial. you can use the voice command to call out other features, such as selection of radio, cd, cd track etc. http://www.e60.net/information/E60_Voice_Commands.pdf
Thanks Bala .... btw how much did the local retrofit cost you? :)
