Auto, Manual or Convert?
nimo
Someone indulge and educate me. Link to the car below:
transmission say auto. desrciption say auto or manual. heck i even see a clutch pedal. is this what you call a convert?
Expired: SgCarmart - Dec '02, 520i
Is converting an auto to manual street legal?
Re: Auto, Manual or Convert?
I think seller meant manual as those tiptronic gear.
I also think that "clutch pedal" is actually the footrest found in most auto cars.
Original manual are not common & afaik, most r converted. As for legality, i m not familiar so maybe those in the know can share their thoughts.
Happy searching anyways! :D
if there's a pedal beside the brake and footrest, then its A CLUTCH! to be sure, how does the car shift up and down the gears when travelling . . . if you need to depress this pedal with your foot THEN ITS A MANUAL! congrats you have one of the very few manuals around. if the car registration log card says auto tranny or something like 520iA then, legally the car is an auto. converting to manual is NOT illegal provided LTA has been informed in writing and approval in writing given by LTA. then you will received a revised or updated logcard that will state the revised tranny eg. 520i.
yes and no as mentioned above.
now this is very interesting. started me thinking abt getting a e34 and converting it to manual transmission. closest i will ever get to an M5... lol!
does LTA provide fixed guidelines to approval? or it's up to them whether they like the car or owner? or is it really about just putting the paperwork together and approval shouldnt be an issue?
mechanically, converting a auto to manual trans; what are the potential complications?
there was also a similar thread started by JONOUK. you could search for 'auto to manual conversion' and access this thread.
actually, there's not much complications as i have had 2 auto-manual swaps done previously and it was a perfect match. best is to have one of the highly respected site sponsors listed in this site do a proper check on the current engine block (and your future engine block if you intend to upgrade) and your rear axle. then, they would be able to recommend or suggest a good match and other considerations. its not only the engine block - tranny - rear axle but also - prop-shaft - mountings - radiator - exhaust routing - dme - programming - brakes - future upgrades in power.
thats' why for my latest ride it was a manual right from the very beginning.
Thanks for the info,
seems like a rather massive undertaking to swap out tranny for an auto to a manual. hmm... trouble is i dun see any E34 MTs around. everything is pointing me back to an E36 MT yet again.
then, be the 1st to besides a e34 m5 la.
Can you share what were your previous rides and the total cost to have each swapped?
e36 - done 2001 10k tranny, ecu re-prog, shifter, shift-boot and pedals only.
e46 - done 2004 22k+ tranny, ecu re-prog, pedals, strengthened prop-shaft, rear-end
new ratios, LSD, shifter with lights, shift-boot, etc. minor stuff.
mine you - tranny had to be strengthened in uk.
must have cost a bomb
true but in my opinion the fun / thrill factor combined with the never ending smile on face was worth the $$.
