Alpine H701
richlee7
Hi all, just wondering how many bros here are using the H701 in their rides... with the present products available in the market, is there anything that can do more than what the 701 can offer in a single, hideable package, i.e. using our standard factory unit.
will look forward to your valuable experiences...
Re: Alpine H701
oneHeadlight said:
iceman using H701... its a good step up. But overpriced at installers..
Hi! Thanks for the update. i understand and saw iceman's setup using the H701 w the alpine hu. any bros using the stock hu so far i.e. incognito... as that is actually what i hope to achieve, as aesthetically, and also the steering controls are still like stock, just hopefully a world of diff in sound... any other bros done it here?
Re: Alpine H701
i intended to do the same actually but holding back... THere is hiss in 701. Not really audible but there is.
Re: Alpine H701
yep, there was this thread fm a forum in the states i came across too... it seemed that they detected that the prob was due to overkill...
fm what i remember, the guy was an installer who did the setup for 2 of his customers. being fanatics, he believe strongly, and used dvs (david navones) to tap the signal for them. apparently, the h701 analog input was optimised for 2volt application (of course higher seems better theoretically... noise reduction, higher headroom etc.) but due to the 'too high/good' signals fm the dvs, the hiss became inherent.
he went through of lot of diagnostic checks, (head, amp., 701, cables, suppressors etc.)
to cut the story short, he finally took out the dvs, and the hiss dissappeared... and he posted this. I could not recall the thread link here, unfortunately. it was some diy forum they had there.
as such i wonder if the hiss that you refer to here is similar in nature (too high/good signal). alpine designed the H701 for 2 types of input for typical (optimal) usage:
1. digital network (using with alpine headunits)
2. analog network (for use with OEM headunits, which i believe they optimised for in their design)
the power that the us guy did was 100Wrms active front (2 way) and 75Wrms rear... so i believe most of us would be running in this same range, so i believe his rectification was correct (in isolating that the hiss was caused by too good signals fm the dvs).
fm some little electronics knowledge i recall, it is possible, as the dvs actually 'clean and boost' the signals, meaning they do have components that will not be considered by the alpine engineers when they designed the H701, since the alpine guys will probably use a 'typical' low quality signal, and clean it up internally within the H701, which in turn, if put together with the dvs' signal circuit, might just not match.
i dunno if you will want to give it a shot, and use a 'normal' interconnect instead of the high end dvs for the analog signal we tap fm our headunit. let me know what you think. do you have a live sample of someone with this hiss problem? could he be using some high end convertors too? or even more coincidentally, the dvs, which i noticed that there were some thread discussing the dvs?
hope i am not misinterpreted. david navones are good, but to match it with the H701, it might happen to be too good. if to normal amplifiers etc, i think it's probably one of the best in the business... i'm very tempted to try the H701, personally, cos i still like the 'stock' look (intend to hide the controller into one of our dash board storage area), but yet i want nice clear sound and image/staging. let me know your take? or any other bros who've tried/heard/read?
Re: Alpine H701
THe H700 has inherent hiss problems, they upgraded to 701 and still there's hiss. Many of enthusiasts i know uses or used either H700/701 before, and mentioned there's hiss. The thing is, its not really audible. I "heard" it once and i couldnt really hear. So i thought my ears have problems...so i consulted my "sifu" and he told me its not really audible and it doesnt matter if u are not going for competition. I was tryin to hear it in a fren's car, and he used it with alpine 9835.
The best is to use an optical headunit (alpine or otherwise) and uses an optical interconnect to connect to the H701. but those with golden ears still claimed they can hear it..but i doubt so.
So I believe it has nothing to do with navones, althought this is an issue i would share with u guys after two of those who used the NE-774V claimed "interference". My ICE project is stalled so i dunno. But apparently reducing the gain eliminates the "noise"...so this shows how strong the navones convertor can do its job.
Re: Alpine H701
got many guinea pigs already haha... my Ice project stalled... may even give up or do minimal. If u go to e46fanatics....many have used the H701 with stock HU...and they claimed amazing results. The hiss is really in audible...if people dont say, many dont know also.
u go do la...
Re: Alpine H701
errr... hopefully within Oct.... should be able to get it done. simple setup onli...
