Aircon Temperature Settings poll
NeulonB
F30s,
What Temperature do you set your aircon usually in this weather? Somehow conti car's aircon is weaker than the Japs...gotta make the temp lower and the fan higher....:|
I'm on 21C, 3rd speed for Fan set on Auto mode.
Is this the norm here?
Re: Aircon Temperature Settings poll
It depends on how your car is tinted makes a big different. My car is standard tint (LTA approved specs), on a very hot day 22C, 3rd fan. Normal, 24C 2nd fan is enough.
In the morning, 1st fan 24C on Auto
Afternoon hot sun, 3rd fan 20C on Auto
Evening, 1st fan 23C on Auto
Dark tint, morning, 24c, 1 fan, hot afternoon, 23c, 3 fan. I don't go auto mode. In between, 23.5c, 1-3 fan.
I read that it is better to put in Auto mode if not compressor or something will kaput very fast..
According to my SE, select M Mode, so that outside air don't get in.
And never set temp above 20, as advised by tech staff so that aircon will not hve "mouldly" & musty smell
Never set temp above 20? So you always set 16 to 19 degrees? ... wow
Dark Tint, temp setting 21 deg permanently- morning 1 to 2 fan, afternoon 2 or 3 fan. Not on auto mode.
Usually 19.5 to 18 depending on the weather
Btw it has 3M solar film - crystalline dark
It depends. I guessed it is about working the air con compressor hard.
If auto mode but achievable temp such as 23-24, I think the compressor will not be forced to work hard.
