Aircon settings
ht
Hi.There's this problem such that the aircon setting is changed from recirculating air mode to nothing.The aircon is set on auto.However,this happens only when i restart my car.Any idea whats wrong?By the way,my drive is an '04 520. TIA
you need to bring your car in to PML and say that you do not like this setting. hook your car up to their modic and change it to the settings you like. they'll probably charge you for it so you might want to cham siong with the CSA to tolong a bit.
alternatively, you can also go to any of the indi workshops with modic/gt1 to code your settings. but they'll most probably charge about double of pml's $30+ (last i checked). anyhow once you are there go through the whole list of default settings that you may be able to change and decide on what you'll like the car to be set in, since you'll be paying the same one-time charge anyways might as well not waste it.
