ADVICE:alightment needed if change to 19 inch??
Arsony
hamann,
Yes, you do need to realign. More for the back wheels. The front do not need realignment. It has to do with the camber angle.
Arsony
Topaz Blue NOT maligned...
better to go for alignment, you can try riverview or keng tiong autos at sin ming 1st floor, or any others since the machine is largely the same. some places simulate weight by placing sandbags in the car. alternatively you can just kun in your car when they doing alignment. hahahah
Re: ADVICE:alightment needed if change to 19 inch??
hamann said:
hi guys...i was using 18 inch ...recently just change to 19 inch...do i need to do alightment again...and where to do the best alightment in town??
please advice...thanks pals! :) :) :)
Best alignment in town? I can intro hook you up with someone that does alignment for most of the Ferraris, Masaratis and Porsches in town.
Sprint.
thanks bro....appreciate yr advise...!! :)
Arsony said:
hamann,
Arsony
yo thanks man!!!! 8)
hi there..where to do the best alightment in town...
pls advise..thanks for 19 inch rims...
Sprint.
Sprint.
Sprint.
Where is this place you are talking about?
What will happen if no alignment done? I upgraded my stock 16" to 18", did not do alignment, and did not feel anything amiss leh..
tategoi, as far as I know, 5er has negative camber, if it is not aligned within the spec, you may get accelerated uneven tire wear.
I just had mine done (E39) at Riverview last Friday, Kenny (90921015) is a very friendly guy.
