8psi pulley size for ASA SK1
danielO
Need to check, what is the correct size for boosting 8psi on a ASA SK1 for a E46 '01 325. thanks
Re: 8psi pulley size for ASA SK1
145mm for m54 2.5L.. :D depends on the engine.. urs is m52?
M52/54 er.... i do not know la.
But i have just found out that my slightly small than 130mm is the correct size for my Infinitas-ASA SC kit.
Tecknic SC kits use the 140mm for stage 2.
Do not know the reasoning, but maybe infinitas's SC design is less efficient?
daniel,
yours is m54.... :)
err.. but doesnt make sense.. both using the same blower.. infinitas uses smaller intercooler than technik.. so technik kit with bigger i/c shud be using smaller puller to produce the same boost ?
I also don't know.
If you get buy a Tecknic Stage 2 SC kit, it will come with a 140mm pulley.
If you buy a Infinitas Stage 2 SC kit, you will get a 128mm pulley.
Maybe the plumbing, I/C etc makes for the difference?
:screwedu:
danielO said:
I also don't know.
:screwedu:
daniel,
if u surf e46fanatic.... ask a guy called samir (he goes under the nick called tecknic)
grand master sifu with matters on tecknic SC.........
cheers,
eddie
p/s: Sorry me N/A dude......... :oops:
