2006 320i Gear Change Jerk
nuk
Hi all,
Just wanted to share my positive experience at R2D.
Been having jerk problems over a few months and it finally got so bad that I could no longer anticipate the erratic gear jumps.
Sent the car to Rod, and he managed to pinpoint the issue sharply and fix the solenoids.
Gear-change is smooth and car has been driving great ever since! So do drop by Doctor Rod, in case you get various mis-diagnoses at other workshops.
Re: 2006 320i Gear Change Jerk
I have this problem too.Mind sharing how much it cost?
Can share the cost too? Thanks!
Hi my first post! I too experience a slight gear jerk on the 2nd gear, esp on full load. Is it a similar problem? Of are your gear jerks bad throughout the entire gear changes?
nuk;868007 said:
Hi all,
Pls PM me bro
Thanks
yes the jerks were subtlety bad enough to ruin the driving experience. after changing the mechatronic solenoids (pardon me if i get the technical terms wrong),so far so good, no more jerks at all.
At first i didnt want to fix it too, but it kept getting worse so i just gave up and fixed the solenoid parts. i was convinced to change the mechatronics because the jerks felt as if they will spoil the gearbox n clutches in the mid-long term. So took the dive to fix this first before it ruins my gearbox further.
Not sure if i can reveal this, but just wanted to help those with similar issues, R2D charged $1800 for this repair (labour n new parts).
