my front brakes judder whenever i step on them between 80kmh to 60kmh. it only happens in this speed range. feels like when you step the brakes the first time when your discs are rusty. has anyone ever experienced such a weird thing and how was it fixed? damn irritating.
i changed the control arm bushes not too long ago.
must mention that the problem only appeared when i slapped on a bbk, so must be the brakes. or could it be a rim balancing issue? so strange....only happens when braking in that speed range....
i can only assume that when u slap on yr bbk that included a brand new pair of rotors, now what about the brake pads ? new one or used. If its a used pad this is where the problem may lie, would recommend u grind them flat as it maybe uneven on the contact surface and this is what causing the juddering.
As wat Mracer77 says, only these 2 things can happen.
discs were skimmed and balanced and the pads are new.
work shop claims that it's cos of the pads and recommended that i bedded them in to see if it goes away. well, it's getting worse. will try balancing the rims next, but i think it may be cos the person who did the grinding may have done a lousy job ending in uneveness in the disc surface. sigh....problematic mod.
if that's what you suspect, let the workshop know and see if they'll take a look and get the discs machined again. it'll probably take half a day to a day depending on the machining shop's scehdule.
