Pss9 Vs Kw V2
shaaz
Legendary 10 Years
Which wld be a better pick or are the both around the same?
Re: Pss9 Vs Kw V2
Should be comparing PSS9 with KW Var 3.
PSS9 has discrete adjustments, Var 3 is depends on number of turns.
Re: Pss9 Vs Kw V2
The PSS9 should be compared to the variant 2 and the PSS should be compared to the Variant 1
Correct me if i am wrong
http://www.bmw-sg.com/forums/contri...kb-handling-questions-solutions-your-bmw.html
B16 PSS9 http://www2.bilstein.de/en/produkte/tuning.php3
The height and force adjustable suspension for maximum vehicle control, especially when driving on the limits.
Masterly Control!
It's fabulous, the car reacts to the slightest steering movement. Man and machine mould into one. Absolute control over the car means you are driving in a new dimension, in a different world. The "Nordschleife" of the Nürburgring flashes past. Personal lap record. The adrenaline surges - what a day ! The technology: the threaded height adjustment feature allows body height and vehicle balance to be adapted to individual needs.
Nine damping force settings are precision adjusted on the compression and rebound strokes to give perfect set-up. Just a few turns of the hand to effect all adjustments with the suspension fitted to the vehicle. BILSTEIN racing technology for the road.
http://www.kw-gmbh.de/en/30_Products/20_KW_Coilovers/20_Variant_2/index.php
Variant 2
and personalized with adjustable rebound damping
The system intended for the experienced driver who requires to not only determine the individual lowering
of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
Damping technology with individually adjustable rebound
• inox-line stainless steel technology at no additional charge
• Individually height adjustable
• German TUEV-tested adjustment parameters
• High-quality components for long life
• Comprehensive documentation for ease of use
• Infinitely adjustable rebound damping
http://www.kw-gmbh.de/en/30_Products/20_KW_Coilovers/30_Variant_3/index.php
Variant 3race technology for the road with adjustable compression and rebound damping
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Independently adjustable damping technology -rebound and compression damping
• inox-line stainless steel technology at no extra charge
• Individual height adjustment
14- level adjustable compression damping
• Unique, independently functioning damping power adjustment
Re: Pss9 Vs Kw V2
KW V3, wooh.. anyone tried that on the track yet??...
but i think KW V2 and PSS9 are good enough. Anyone tried the KW V2 on track b4?
8may88vip
