PML WS did not fix my problem! - engine vibrates while idle
iankaw
Went complaint abt the problem, but problem still exists after engine mounting replaced. Why didnt they change transmission mounting at the same time?!
now I gotta go back one more time for the same unresolved problem? this is uncalled for if they did a proper job. Do I get a priority? Is it bcuz mine is under warranty they are stingy on parts?
any advise how to deal with them?
TIA
Re: PML WS did not fix my problem! - engine vibrates while idle
TIA
maybe is ignition coil that is faulty ?
Ask them to do a rough idle test first .........
My thoughts : Why do we need to tell them what to do since they are the expert? I can understand those who is mechanically inclined to know whats wrong with the machine but for layman, what can they do?
Just go MA!!
Difference between PML n MA w/s??????
One got MADchanics n the other Mechanics
MADchanics had worked with Ronald Macdonald before...........:shock:
PML adjusted the RPM to 700, no more engine vibrates when idle... hope they are doing the right thing
your problem solved? so above all feedback not correct?:shakemyb:
BUT PML also did wrongthing for not doing right in 1 time:shakehea:
just curious your e60 still got warranty from PML?
you extended warranty? how much ?
shawnloh1221
