Oh.. ok i go check it out. Thanks ya,keanw1;188225 said:Hi Jewell...someone did post on website asking the same question and Terry (nick) I believed replied.
Jewell_sg;188234 said:Oh.. ok i go check it out. Thanks ya,
Thanks Terry! Yes i want to mod my car exhaust. But i want to buy 2nd hand. Pls let me know u got 2nd hand. I lost my ph so lost yr number too. Can u PM me yr number again?Terry;188331 said:jewell sg.... as long as all 4 rims are of the same size...it will fit
btw.... i heard frm mike u looking for some mod parts? let me know... i will source it for u used or brand new
Hi Terry, I'm the one that wants to buy Jewell's rims & tyres. Problem is my E46 is having a 16" rims with tyres 225/50 R16, but Jewell's rims are from her E90 with tyres 225/55 R16. I've done a calculation, and the overall diameter will be increased from 631mm to 654mm, which is an increase of about 3.6%. I've checked on some websites and was told that it's not adviseable to do so, as the speedo will be out also. Any comments on this?Terry;188331 said:jewell sg.... as long as all 4 rims are of the same size...it will fit
715;188668 said:Hi Terry, I'm the one that wants to buy Jewell's rims & tyres. Problem is my E46 is having a 16" rims with tyres 225/50 R16, but Jewell's rims are from her E90 with tyres 225/55 R16. I've done a calculation, and the overall diameter will be increased from 631mm to 654mm, which is an increase of about 3.6%. I've checked on some websites and was told that it's not adviseable to do so, as the speedo will be out also. Any comments on this?
TripleM;189041 said:All 5 series rims CAN NOT be fitted onto regular E46 models.
Terry;189044 said:not the staggered one... if its 16x8 all round.... i suppose it will fit right?
wow.. seems like its very complicated. Better don't try.....ninja07;189046 said:even if this is the case, if I am not mistaken, it will not fit.
E60 has low positive offset range, whereas E46 has high positive offset range. You would need some more than 20mm spacers (very thick) to push the wheels outwards to bring E46 offset down to E60 offsets. Not to mention some serious fender work too.....
Nvm .. Is ok.. Thanks for helping meTerry;189223 said:ok...my bad...i guess it wont fit..
