this topic of tyre pressure has been debated very often.crombie_sg;477107 said:hi guys,
Just want to check, what is the normal air pressure that you use for your tyres? I use 36 psi and I can feel all the bumps being transmitted thru the steering. Is the pressure too high or the wall too stiff? My tyres are Bridgestone RE001 245/40/R18 97W. Any comments?
really LL wan. no easy way out. what i do is that i keep a tyre pressure gauge with me so that it is easier for me to assertain the actual pressure in my tyres.crombie_sg;477127 said:slater,
I appreciate your insight. You are correct about the trial and error method, except we find it tedious to do.
I was in the same situation as you yesterday..so consulted a car expert and he said go with Eagle F1 asymmetric..I went ahead...immediately can feel the difference between stock RFT and this F1..F1 has much more grip and also quieter than stock RFT..i'm quite certain PS2 should edge out a bit more vs F1..at the end of the day, F1 is enough for my needs...maybe PS2 at next tyre change..Hendrick;477082 said:Hey folks,
It's about time for me to change my tyres, 235/35 front , 275/30 rear, 19 inches. Any advice on the above 2 mentioned tyres?
Slater;477130 said:really LL wan. no easy way out. what i do is that i keep a tyre pressure gauge with me so that it is easier for me to assertain the actual pressure in my tyres.
pump one pressure, drive for a day or 2 u shld be able to tell if its too bumpy given that u travel they same route to work everyday.
u damn right!crombie_sg;477157 said:Slater,
Now I see a guy in nice shirt checking tyre pressure in the car park, must be you lah!
Slater;477174 said:u damn right!
i think i kena poison liao.EMF;477179 said:... Bro, why am I not surprised, U da ON sia!
