Dyno in Singapore
titanic
Is there a list of workshops that provide dyno services here in Singapore? I am looking for Dynapack dyno in particular.
Re: Dyno in Singapore
hmmm why dynapack, you like the figures they produce? lol
Dynapack is stuck to rear wheels, much more accurate than those roller type where friction is a function of how tight you tie the car down.
so how is that accurate? your car runs on wheels, not axle bolts. friction is everyones problem everyday, so why dyno without it? Plus i seriously doubt you have enough HP to roll the tyres of a roller.
Hey Phil, titanic just wants to reduce variance from tire type, inflation pressure, strap tension and angle. It is valid thought.
yes i know, i like that dyno too. but i doubt he has a race car, so a regular dyno would be enough
but the variances are present in road cars as well
Titanic did a previous dyno, but the result was FAR below the documented HP for his car. So he would like a second opinion from a superior dyno.
hahaha, below Hp, here we go, another dyno thread and expectations. Where was the documented HP from? I mean what country? what conditions?
this thread will go on for days and days.
Rim size, humidity, altitude, air temp plays a part..in Singapore, HP sure low.
The main chassis dynos in Singapore are hub-type and rolling-road (inertia or eddy current). There are other variations of the rolling-road like water-brake but AFAIK none are in Singapore so will omit them from the discussion.
The most common hub-type is the Dynapack. As pointed out the wheels have to be removed and thus there are no frictional losses due to tie-down pressure, tire deformation etc. So assuming that there is no correction factor applied the figures you get should be rightly considered as "power/torque at the hubs". It may very well be the case that Car A with 350 PS at hubs will lose out to Car B with 350 PS at wheels, because tire and rolling losses were not accounted for, ceteris paribus (same car model/transmission, similar shifting speed and pattern etc). Then there are certain places where correction factors are not only applied, but used liberally and indiscriminately. :screwedu:
As for rolling road, the inertia types are the Dynojets, Hyper Dynos, DIMTech etc. Fundamentally these dynos calculate the force required to move a fixed mass (the rollers) at a measured rate of acceleration. This makes them pretty much useless for dyno tuning because the tuner will not be able to hold a steady load/RPM site and thus alter that particular site and see the effects in realtime. They also usually lack sensitivity and thus require smoothing functions to present a nice curve. Another major problem is that since they are measuring inertia a "tuner" could cheat by just changing the wheels to something less heavy and you get "free" horsepower. About the only thing they're good for is a full power sweep. To address some of these issues a lot of these inertia dyno makers have a "retarder" option to allow actual tuning to be carried out. How good these are, the sensitivity, hysteresis, overloading, all vary.
The best I've seen to date and seriously recommend are the Dyno Dynamics dynos. There is one at Subaru in Toa Payoh and I only use that. The dyno operator there is competent and knowledgeable. The dyno is calibrated on a regular basis and produces realistic figures, which are further reinforced by my own GPS test data. I have done repeated back-to-back runs and the power is almost always within 1 PS of one another. The only trouble I had was dynoing an automatic MINI which was always kicking down whenever full throttle was applied.
There's also Mainline Dyno which is receiving good reviews worldwide unfortunately I do not know of any in Singapore.
i9bet9club
