Aloy27;870093 said:Or u can chose to wrap yr car will cost lesser den new paint works... But if gana dropping again u need to keep changing the wrap.. Best to change paint wif hard solid laquer ... Even the cat urine can't penetrate....
Did u compare the paint's age for age? Also BMW and VW was 'hit' by which breed of bird shit (different breed has different acidity)? Otherwise I think it's a pov which cannot hold water.clamsgp;870739 said:Sympathize with you. My F10 also kena but luckily just a couple of drops. It appears that the paint work in BMW cars is not so robust. My Golf GTI paintwork could withstand bird shit alot better.
MW;870097 said:I saw a bright orange Lexus IS250 this morning with quad oval figure-of-8 pipes on Changi Road today... ur fren?
Baby1M;870880 said:Did u compare the paint's age for age? Also BMW and VW was 'hit' by which breed of bird shit (different breed has different acidity)? Otherwise I think it's a pov which cannot hold water.
Any no offence intended, just clarifying to up my post count, ROFL.
evilbear8;871349 said:BMW paint is quite hard, though not as hard as lead based car paints of old. Not sure if its as solid as the VW's though. I heard from a few people that VW group's Audi and Lambo paints are rock solid as they use ceramic coats where as most other manufacturers use water based base and clear.
If VW group uses the same ceramic coats on their VWs, should be more durable than BMW's. Believe a lot of detailers on specialist car detailing forums state that a regular audi A6 paintwork has a hardness of 5 on the MOH scale.
One way of enhancing the hardness of car paint and preventing toxic etching after manufacturing is applying opticoat/optiguard or cquartz finest. Will normally increase your hardness to around 7-9 on the MOH scale.
With etched toxic bird poop, you may want to just pay a professional to do paint correction. Its not cheap if properly done but it will make the paintwork on your vehicle better than when it left the factory as paint correction also corrects factory paint defects.
Way the bird must have used your car as a toilet... A4 size is no joke. Go for a good grooming session shld do the job.flyboy;870781 said:Thanks for all the advice, tried all conceivable means, except respraying, damage has been done....
Saving grace is that the affected area is only on the top of the car, total area about 1 A4 size area.... sigh
DAMN THOSE BIRDSSSSSSS!!!!!!
MW;871280 said:Yes, even spray painters and groomers say BMW paintwork is among the best in the mkt
