316i Transmission Oil needed
As long as you put back the same amount that you disposed, or made sure the level is full, it should be fine. You can never get a 100% change unless you do a transmission flush (which I think is not a good thing to do anyway).
initial workshop told me i need abt 8 litres including filter replacement. i didnt change the filter so the most 7 litres but then we didnt measure the dispose fluid. i was abit startled when he said its full when we fill slightly over 4 litres
Oh, I thought you DIY
If the workshop knows what it's doing, and made sure the fluid is full, then it should be OK. But might want to go back after a few days to double check.
