WTS: ESS E9x M3 VT2-625 Supercharger
impavidus
ESS E9x M3 VT2-625 for sale
Item has been dekitted and is available for C&C
Fully ready to plug & play. This is a bolt-on kit with no engine modifications required. Item can be very easily installed at an experienced workshop.
Description
courtesy of http://esstuning.com/e9x-m3-vt2-625-intercooled-supercharger-system/
The mid-level intercooled E9X M3 VT2-625 supercharger system produces 625hp and 410lb-ft of torque at 6.5-7psi of boost. A 211hp gain over stock, which is more than a Mercedes SLS Black Series.
Featuring the self-contained Vortech V3 supercharger unit in Si trim, the supercharger is capable of producing up to 775hp. The VT2-625 comes with the largest capacity liquid intercooler system on the market integrated within a specially developed cast aluminum intake manifold assembly ‘ribbed’ with optimized runners and velocity stacks. This ensures the intake charge temps remain in check during prolonged use on the track, autobahn, or street. The manifold was designed not only for optimum flow, but for minimal weight to not disrupt the iconic handling balance of the M3.
VT2-625 specs:
Boost pressure: 6.5-7 PSI Intercooled
Horsepower: 625 SAE (~48-50% gain over stock)
Torque on: 410 ft/lbs approximately 550Nm
Kit has been painted a sleek Satin Black to blend with the factory engine bay, similar to photo shown.
Photo credit http://www.superstreetonline.com/features/1404-2011-bmw-m3-z4-m-coupe/
(edit) SOLD :)
I don't check the forum frequently so responses may be delayed :)
