WTS: BMS POWERBOX (e60)
qwerty123
looking to sell the above.
BMS power box for e60; $280. Kindly leave your contact if keen. Thank you.
What is the BMS Power Box?
The BMS Power Box is a BMW Performance Chip made specifically for the BMW inline six cylinder motors. The PBX also has an adjustable throttle feature that can be combined with the Performance chip feature by selecting a setting or "map" as we call it. The BMS Power Box contains both a performance chip which gives you an extra 10-15 Horsepower at the wheels and an adjustable throttle boost feature that makes the gas pedal send a boosted throttle signal in increments of 30%, 60%, and 100% over the stock BMW signal. Depending on what setting/ "map" you select you can create a perfect blend of throttle response and horsepower and torque. For maximum horsepower and throttle boosting select MAP 3. The BMS Power Box is completely invisible to the BMW dealership and testing equipment so you can leave it in for routine service.
What will the BMS Power Box do?
The BMS Power Box will make your vehicle more responsive, spirited and fun to drive. It will make your vehicle faster by increasing the horsepower and torque. It works well with other modifications like intakes and exhausts, but can also be used alone. It will remove the "dead space" when you push on the non responsive stock BMW accelerator. It changes the way the car drives and feels. You can turn it on and off from the comfort of your drivers seat to feel the difference. The BMS Power Box is the clear choice.
How does it compare?
Other products just have a single setting throttle booster. No horsepower/performance is gained or you have to reflash your ECU and there is no throttle boost feature. They are costly and are detectable by BMW's equipment.
