windscreen repair
oneHeadlight
i've got quite alot of small little pinholes damage on my windscreen, probably from road debris..
any recommendation for place to repair ? thanks.
Re: windscreen repair
better to replace the windscreen dude, under insurance. allow PML 2 days to do it (to cure the seal fully). as good as new! hope this helps.
cheers,
yes, the CA advised me to change since i have a couple deep chips which he said can't be repaired. Go seek out your SA, good luck bro.
cheers,
thanks bro.... but mine is pinhole kind of damage...barely noticeable unless very particular like me.. anyway, will check out.
my advice....think twice when changing windscreen buddy! what if.....after changing, you get some wind noise from nowhere...how?
Hi Bro, i change my windscreen before by PML. Till now no problem. But case to case basis, i cannot say confirm no problem like wind noise as mention by tom_ting.
thanks guys...but i think those pinholes are way way too small and too few to go thru the hassle fo changing my windscreen. Moreover, i got tinting on it.
i know of those windscreen repair people, just surprised no one is sharing !! :(
thot i read before in this forum got some windscreen repair specs. did u do a search?
i read one thread about something similar but the thread is about i think a couple of years back....not sure if its relevant. SOme AHa-image workshop...
Bros, I found a small crack on my windscreen today .. most likely from my recent travel to Malaysia ... PML said can replace without charge, but I'm concerned abt probs after replacing the windscreen ... saw some earlier comments below ... any bros have any relevant experience to share? Cheers ;)
