Spacer for e90
labbit76
Need some advice. Can someone advice where I can get spacer? Anyone have added spacers for their rims, please advice if there are any issues by adding them.
Many thanks in advance.
Labbit76
Re: Spacer for e90
Make sure the spacers are hub centric and you should be fine. Measure the roughly how flush you want the wheel to be with the fender (without causing a rub) and then decide on the thickness of the spacers.
IMHO - Try not to go beyond 20mm.
Re: Spacer for e90
Thank you. Do you know where I can get the spacers from?
Re: Spacer for e90
labbit76;1042222 said:
Labbit76
Check with site sponsors, some of them do carry spacers.
Whichever spacers you choose, make sure they're reputable and use the correct extended-length lug bolts.
Re: Spacer for e90
Remember to post pix after you install :)
Re: Spacer for e90
Boss carry the spacers, same as those Aaron using for his ride.
I have the same spacers but at 10mm only for my ride too, so far so good.
Actually bought used from a nice forumer here that seems to have some steering vibrating issue upon installation, but i have no problem on mine.
Cheers.
Re: Spacer for e90
best use reputable 1 ,
I will not use them infront because is sensitive for front wheel
hub centric is a MUST
and also makesure the screw is long enough to secure both rim and spacer ( I will reco at 6 turns)
but longer(more turns) does not meant better
Re: Spacer for e90
Hi TS,
I just installed the Burger Motorsports spacers all round. Driven around for a couple of days already. On the whole, no major issues as of now. The only problem I faced is some slight rubbing on my left rear fender. Gonna fix that issue tomorrow. Like what most have said, it is a must to get hub centric ones and extended bolts, safety for you and other road users.
Hopefully this might help you in some way or another! :)
Re: Spacer for e90
eugenetan;1042981 said:
Hi TS,
Oh yes, rubbing is the only issue i faced too.
Send for fender rolling liao, but will still rub if going over uneven road at high speed when there's rear passanger.
Mine lowered with 'comfort' springs.
Cheers.
Re: Spacer for e90
Hi TS,
Hi Eugenetan,
Where did you get the spacers and what is your setup? 12mmfront/15mm rear? Are you on 18inch rim?
Re: Spacer for e90
labbit76;1043024 said:
Hi Eugenetan,
I got my front spacers second hand and my rear ones are brand new from Boss. 12mm front and 10mm rear. Wanted to get 12mm all round but was advised not to due to excessive rubbing. I'm on 18" 193M rims.
Re: Spacer for e90
Bro, are you staying in woodlands area. I think I saw your car at civic plaza on fir evening.
Re: Spacer for e90
I was at woodlands on friday evening, but I didn't go past civic centre that day. Was at my friend's place haha.
