Seat belt indicator that remains on
er1cw
Hi guys.
Having problem with my sear belt indicator that stays on even thou both passenger and I are bucked in. It happens only when pax sit in before I start the car. If I start the car before pax sit in, all indications remain normal.
What's wrong with my BMW?
Re: Seat belt indicator that remains on
Nothing wrong with your BMW. Only something wrong with the seat belt sensors.
er1cw;690827 said:
Hi guys.
will there be the sound beepign?
No sound. Just indicator light on the dash. Any idea what is the damage for seat belt sensor fault?
maybe u wanna try some contact cleaner spray 1st, can lend u mine if u need it
Bro,
theres a connector under the seat , fairly commen for these to get caught or have a loose contact or unplugged. get a torch and have a look at the connector under the seat. Try disconnecting it. it is a clip like connector underneath the seat. Try cleaning it like SSzone said, then connect it back.....trial and error....hope it works. it could be a Problematic micro switch too, hope its not.
Monfreeze Archangel;691055 said:
Bro,
Any idea how this connector looks like? Bend over with torch but couldn't find anything that can be pull out.
Bro,
it should look like this one; the black connector....trace the wiring from ur floor board upwards (towards ur passanger seat).....
hope this helps.....
er1cw;691176 said:
Thanks bro. Will look again tonight.
Bro,
Hope that it is just a matter of loose connection. Good luck bro.....
Night job, ensure u have enough lighting.....
Happy HUNTING :)
the warning sound can be very annoying when i usually unbuckle while parking.
anyone tried to disable the warning completely?
put a jumper wire maybe?
