Rims Upgrade for my E92 M3,Help need..
motec-ct9a
other than breyton GTS and VMR V710,what other rims do u guys recommend?i m getting my car soon,if i were to change to aftermarket 19inch rims,must i change tires too?hw much r all these rims and can i use back my stock tires,or must i get low profile tires to prevent fender rubbing?i m planning to install H&R lowering springs,r the height really lowered or almost the same?mine is the 19inch M3 rim,hw much can i sell/trade in with tires?
tks
Re: Rims Upgrade for my E92 M3,Help need..
advan rs are a favourite of many around here...
First, the new M3 rims are v nice..and too bad, not much of value u can get out of it by trading in. So, I'd rather try to sell it separately by posting in bazaar folder.
As for tires, u can use them back of course, given the same specs of the rims u want to change to....
If u get a shorter spring like H&R u mentioned above, of course ur ride will be lowered. The specific spring tells you how many milimeters of lowering.
There are plenty of rims out there..
If u want custom rims, u can get rims like DPE which our bro Kentonna carries and can advise you accordingly
If u want something more of the shelves but still need some ordering time, u can go for high end Neez rims that make specific offsets for a car.
Else the increasingly popular japanese rims like Volk Racing, Advan can be had too..
Gd luck
I am on the Advan RS and absolutely love it. I get a hard on everytime I see the rims. Front 9j rear 10j. Steam.
I think weight, quality (forged) and design wise, nothing beats the Neez QD7.........
Why do you bring back my old memories? I feel like a widow now. Yes agreed. Strength and Weight, the Neez is unquestionable.
motec-ct9a said:
but but the price make me wet too.....
Your car price also make a lot of people wet....... what's three-four thousand dollars difference?
the neez 7model series only come in offset of 35,i suppose its nt aggressive enough or?
You can have the offset for M3 as well. Let Marcus reply you.
When Barry called me last night, Marcus was with me.....
care to share what is most agressive offset for e92 m3 with stock tires if i were to change rims?
what is the max ppl hav tried?
motec-ct9a said:
.....if i were to change to aftermarket 19inch rims,must i change tires too?
motec-ct9a said:
care to share what is most agressive offset for e92 m3 with stock tires if i were to change rims? what is the max ppl hav tried?
Err, your stock tyres are 245/265 on 18"s, how to use on 19" rims?
I believe this should be your wheels? If so, you may reuse the tires for QD7... also... poison poison poison.... i can arrange a set of QD7 for M3 to fit on your car, you see if you like it 8) Its currently off the car so will have to wait till your ride arrives :)
Somehow... just somehow i dont have a proper pic of the QD7 on local M3... just the one on the dyno....
For the M3
Your 19" stock wheels are 8.5 front 9.5 rear with +29 and +23 offsets respectively.
Using Ray's Volks Progressive ME's specs as a guide, your e92 M3 can run +15 front and +22 rear...
PRO_ME
tks alot bro,really appreciate tat,cos i dun wana buy s set of rims that is sunken inside,damn sian 1
Unfortunately the wheels are not customisable... its default set to 35 offset... that said, the wheels are already nearly flushed with the fenders.... Lowering wont be an issue and there is enough gap to fit BBKs...
It didnt cross my mind i had a spare set lying around to test fit (E92M3 only) hence i didnt mention last night... but my offer is always open ya!
Interestingly, these wheels will also fit E39, E60, E63, E64, E92M3, M5 & M6.... i dont know how Neez managed to do this, but it fits these cars so can reuse!! Haha...
