Just ordered a set of Bilstein HDs
Mockngbrd
Administrator
Staff member
Administrator
Just ordered a set of Bilstein HDs for my E30.
But will have to wait around 2-3 month for arrival.
The part numbers are Bilstein P30-0128 and B36-2028.
Anybody here with any reviews of this set of Shocks?
I was wondering if it is posible to match them with Eibach Pro-kit, or should i just leave the stock suspension inside?
sometimes when i do cornering now, even at low speed, once in a while got a "tok tok" sound from the back.. any advise on what could be causing it?
Re: Just ordered a set of Bilstein HDs
I believe those are Bilstein Shocks...
If that is the case, why dont u just get the full Bilstein CUP suspension set up such as Bilstein Street Line or Sprint Line depending on what u are after...
It's always possible to mix n match as most suspension makers such as Eibach, H&R, Bilstein make their springs/shocks that can match your original shocks/springs.....
The question is the ride n handling quality and of coz the rate of wear...
I m not a big fan of mixing springs n dampers of different brands unless they are designed as a kit...
For eg. Ground Control coilver uses KONI shocks but Eibach Springs and both are made to GC's specs
