Ideal tyre size staggered set up for Z4??
mybmmer318
Hi..currently on stock set up..225/45/17 all round for my z4 2.5 and thinking of upgrading the rim size to 18 wheelers and going for staggered set up.. any advise which is a more ideal set up which i can use? I have tried using the tyre calculator and the best upgrade size they gave me is 255/35/18. Wondering is this set up suitable? But i don't think the 255/35/18 can fit the frount as i am afraid that it will rub against the fender during turing..Any z4 owners can advise what is the ideal size to use for the frount if i were to use 255/35/18 for the rears and it will not affect too much of the speedometer difference compare to stock and most impt the safety of the vehicle.
Help appreciated...
Re: Ideal tyre size staggered set up for Z4??
oem 18" staggered set up is 225/40/18 for front and 255/35/18 rear.
Hi, thks for e info..oh btw what is the ideal offset and rim width to select when going for the 18' wheelers in order to fit in the 255 rear tyres?Do i need spacers for the rear as well? Thanks..:)
again using oem specs as reference, you'll need 8.5j width for the rears and an offset of around +40. i think you can try to go as far out as +34 on the rears if you're not lowered.
hopefully TripleM can chime in... he's the wheels and offset guru.
Hello mybimmer318
Like louis has mentioned before, the ideal staggered set up is 225/40/18 Front and 255/35/18 Rear and this is from BMW factory specs. And this set up was fitted on 8JJ +47 front and 8.5JJ +50 rear ( rims 108 model )
That set up is perfectly fine for street driving but in my experience, you can make the handling and look even better but going a bit more aggressive set up.
Factory set up will make the look of the wheels a bit more sunken inside the wheel arches. To make it more flushed without sacrificing increased stress on the axles and wheel bearings, what u can do is to get a set of rims that increase in both widths and at the same time, reduce the offsets to a smaller number ( more negative technically speaking )
So, I'd got with offsets +39 to +42 with 8.5JJ rims in the front AND +40 to +42 with 9.5JJ rims in the rear. If u use +42 in the front, u can slap on 245 or even 255 tires and dial in about -2degree camber to avoid rubbing. If u go with +39, I think u should max out with 235 profile.
But again why would u want to put 255 in the front on 8.5JJ which isnt optimal?
For 8.5JJ u should go 225/40/18 to be optimal or at most 235/40/18
Now it's easier said than done. As I said, I'd lv to hv those offsets n widths but in the end, I settled with +39 8.5JJ front and +39 9.5JJ rear. The results? Superb handling and look. The rims I used were Prodrive GC-07E. Tire sizes for street driving was 225/40/18 and 255/35/18 but for track day use, I used 225/40/18 and 265/30/18 on semi slick tires. No rubbing whatsoever, cambers were dialled at -2.5 front and back, the car was lowered.
If u want to check out the ride, pm the new owner nick-named 33 and see it for yourself.
To recap:
Choose rims with 8.5JJ and offset range : +39 to +42 for the Front
and 9.5JJ and offset range +39 to +42 as well for the Rear
If u prefer with 8JJ and 9JJ then get +40 all rounds. Oz Ultraleggera has such set up.
Gd Luck
Jack
TripleM;171642 said:
Hello mybimmer318
To recap:
Gd Luck
Jack
Wow...indeed e tyres and rims guru...ok..will take your advise and go for e above set up...i might be using koni adjustable shocks and combine it with stock springs..Appreciated alot...
no worries
gd luck n happy modding
