Blitzer
As above, condition 9/10 (just a l'il dirty)
" The E36 M3 Sway Barbarians is a very unique set of bars. The rear is an asymmetric shape, allowing for a fit unlike any other aftermarket sway bar. Most aftermarket swaybars will usually wind up hitting the exhaust system under full droop situations (when the rear suspension is complete extended such as on a lift). The Sway Barbarian has a unique bend to less this possibility.
Professional race quality. Used by world-class racing team ERT in the Speedvision Motorola Cup series and is the official BMW CCA design for SE36.
Quality. 100% made in USA with computer-controlled fixtures and precision water jet cut ends.
Superior Adjustability. The SwayBarbarian uses a multi-hole system on the front and rear bars which allows for fine tuning of the bar for whatever desired effect, without sacrificing body roll.
Model Front Sway Bar Rear Sway Bar Front % Stiffness Rear % stiffness
Stock '95 M3 0.88" (22.5mm) 0.748"(19mm) 0 0
Stock ’96 – ’99 M3 0.905" (23mm) 0.787" (20mm) 0 0
UUC Motorwerks 1.0" (25.4mm) 0.9375"(23.8mm) 62% 147%
Sway Barbarian
Racing Dynamics 1.0625" (26.98mm) 0.875" (22.225mm) 107% 87%
Dinan 0.875" (22.225mm) 0.875" (22.225mm) -5% 87%
Selling $180 neg.
pls contact me at 96653300
Sway Barbarian
Selling $180 neg.
