Engine oil leakage
jojosnr
was advised lat weekend that my e90 has signs of oil leakage and is advisable to change the sump and other related parts. will cost close to 1k and 1 day of work.
anyone has similar problems before ? is it common ?
Re: Engine oil leakage
E90 quite common for water seals n oil leakages after 2 yrs onwards.
just got mine done at BVO, it is normally the oil sump gasket that is worn, should cost about SGD 300 thereabouts only
in the mean time, u can ask them to check if there are any other water seals or gaskets leaks too.
Need advice from bros,
Current E60 ('06 523) experience 'trembling' at low RPM
There could be several reasons for the oil leak. If its the gasket, then its a few hundreds buck but if its the vacuum pump and solenoid, it will be $2K+
jojosnr;427024 said:
my case is oil leak from O-rings & seal of oil filter wch are common due to harden plastic bcos of high operating temp. sump is ok. Y2006/ 85kkm
wch year & mileage of yr car?
Thanks Pals for all your valuable replies.
Mine is a 06' 523i at 120k mileage. You were all rite :thumbsup:as they confirm it is ignition coil and gasket issues.
Where did you go for your such repair works?
WS @ AT performance, blk14 Sin MIng Ind estate #01-21. Boss is Alvin. WS is quite messy if u dont mine. If ask, just said is rec by 8876 (car plate). Go there before 9am to avoid long Q.:D
