E60 Spare Tire
Re: E60 Spare Tire
bmw01sg;716775 said:
May I know if E60 spare tire can fit on F10?
Tks in advance!
john
Hi
You sure the e60 comes with a spare tyre? My 08 525 does not have a spare. Neither do I see the jack and wrench.
I wonder should I buy a 17 inch (same model) rim and the jacks and use as spare. Or, should I get one of those spray seal and an air pump for emergency use. I am looking at this option so as not have to use RFT.
Thanks
Re: E60 Spare Tire
My SA gave me a spare tyre when i bought my E60 3 yrs ago.
Now I had changed to F10 n Not sure if it fit.
Re: E60 Spare Tire
I dont even see the jack and wrench. Is it standard that these are not provided in the e60? Maybe expects everyone to up rims to 19 or 20 inches so these were removed?
maybe should Just go with the flow and get the run flats
Re: E60 Spare Tire
BMW advocates run-flat-tyre ... no need spare tyre
if owner choose to change out RFT to normal tyre, it's own choice own risk
get a tyre repair kit that plugs into cigarette plug and inflate tyre with temporary sealant
Re: E60 Spare Tire
I think I will likely to go with RFT. will decide in March as I will be driving up to Penang.
Thanks
Re: E60 Spare Tire
hi u may wan to check the setting.. wif the mechanic...
Re: E60 Spare Tire
SpoiltBrat;717823 said:
Hi
Thanks
my 2008 e60 LCI have a spare tyre wif all the required tools neatly intact leh.. :huhhuh:
Re: E60 Spare Tire
I had bought Airman repair kits for my F10.
So if any E60 owner keen to buy my spare tyre, pls PM me.
Re: E60 Spare Tire
OK so it does come with one. Thanks
Re: E60 Spare Tire
Hi
My car is an e60 525 2008 model. it is using 225/50/17 now. I presume yours is the spare for this model or at least suitable for this model. Will it be usable if I were to use 235/45/17 later for my car?
Does it come with the jack and wrench?
If you are selling it please give me a pm on the price. I will consider this instead of replacing with RFT if it is suitable for me.
Thanks
