Re: E46 M3 Supersprint cat remove need help
Calvin
I hv no experience in the SS mid pipes but I guess similar solution applied when I fitted my UUC mid Rasp-X which essentially "removed" the two cats too...
From the factory, there are couple of sensors which are connected to the twin cats and when I fitted the UUC one, I had to get the sensors welded back onto the new pipes. Final result, no engine check light.
I think u will have to do the same else those two pieces of sensors will be dangling ard and potentially, will cause engine check light to come on
Hope this helps
