Change Engine mounting & Transmission mounting
Ahbengdriver
Legendary 10 Years
Ooiii Hiadees, the Lunar 7th month has arrived. And soon its mooncake time. Ok that's not the topic here, soli.
Came across many E9Xers who had changed their mountings. Usually mileage of their cars are between 100000km to 120000km range. Most had been advised to change them by WS who spotted wearing or are asked to changed them because "it is about time". Apparently these wear-n-tear items causes the car to vibrate unusually during start-stop. Google it and you will also find that 'experts' says it affect some other things. Essentially its like the Engine and Tranny are wearing worn out shoes so time to change your sandals.
SO AH...ERR HMMM. is it a must to change this? Yours truly's pariah-es are 100k to 120k liao but I haven't felt those so called vibrations leh. Hope the residents of the 7th months wont come and vibrate my car of course.
Re: Change Engine mounting & Transmission mounting
This is the old and worn off engine mounting
This is the new ones
This is the location of the engine mounting
Please have the car lift up and check the condition of the mounting and then u decide if u want to change the engine mounting
Don't think you are going to be able to check the engine mounting by just looking at it from below ........
And are you suggesting that ABD take out the engine to compare with s new one to decide ?
Have it inspected at a BMW workshop then
Bro Aaron, that first pic of the engine mounting looks terrible. whats the car mileage when it looked like this. This can serve as a guide for other car owners.
That time was 140,000 KM mileage.
Hope my pictures help u to decide better if u want to change the mountings
If your engine has sunk in by 2-3 cm then you should change.
Do this with your hiadee -
- start engine
- step on brake
- engage D
- open bonnet
- ask your hiadee to look at engine
- rev engine to 2k rpm (do not release brake)
- stop rev
- ask hiadee see engine tilt to one side by how many cm just now
- repeat if hiadee miss
And if changing engine mount - usually also change transmission mounts also if never change before.
Using mileage to gauge whether need to change not zhun because wear and tear also depends how you use your right foot.....
Red_Bean_Bun;1094374 said:
Which one would you recommend ?
Let me guess - the one in JB ?
Which one would u?
i changed my mounting at 40k km @ 5yrs old. felt vibration and rough drive... after change, all smooth and good... can see the old mount sink in but not as bad as the bro whom showed the picture...
I just changed bushes at the front after I had slight vibration at 90kph . Now all smooth .. Mileage is 123000 . And they looked liked Aaron's very worn out . U can test it by driving forward even at slow speed and hit the brakes hard, if u hear a clung then it's time to change . Hope it helps
Engine mounting wear rate are very subjective. Some wears off earlier than usual. It all boils down to your driving lifestyle.
Mine was replaced at 80 556km Mileage (13-12-13, car age 3 years one month plus) together with the gearbox mounting.
It wasn't as bad as Aaron's picture actually. I felt my dash board vibrates during picking up.
My advise : Get Original BMW ones (as in BMW packaging) OEM ones will not last.
Cheers ~~~~ :)
Hearsay some get 335 or M mounts as replacements for E90s etc ......
http://www.bmw-sg.com/forums/bmw-3-...006-2011/43482-e90-318-335-engine-mounts.html
Cheers ~~~~ :)
Hi guys, yes the engine/gearbox is one of the more common parts which people change due to wear and tear. Do contact us for a quotation for your rubber mountings or other maintenance parts.
Eng Soon Auto - Your BMW Oem Parts Specialist
Hi seniors ...
Let me share with you ... 335i warranty left 1 year plus.... back then
At 40,000km i feel more vibrations on my steering and at Munich ... they say no need to change ...
Went to 5 different WS in this website and all confirm engine mounting ...
They say computer say no fault!
SO have to bang table and ask them explain why vibrations ... they say my car is sports car so is very powerful car and sure got vibrations ....
In the end after my slam table, they say they will change for me 1 unit... so i asked how many units on our car ... they say 2 ... WTF ... so i agreed to pay 1 set on my pocket and same for transmission mounting ...
TMD ... 170 for 1 side of mounting ... (from eng soon you can buy 133 + 33 = 1 set) so again kana smoke. Same for transmission mountings as well ...
According to workshops ... these are rubber and when under load they are compressed and when due course and stressed they sagged .... If you feel heavy vibrattions do change then and compare the new vs the old ones ...
after change vibrations minimium or none ...
Now car at 65k .... starts coming again ...
Not too sure if e 92 mounting can upgrade to M (e92 mountings ?) hearsay some mounts are meant for manual cars ...
Your 600nm monster would need better mounts for the engine, transmission and rear diffs.
Engine see if can order the 335is mounts on the right side.....Vorslag for the transmission mounts ....and delrin for the rear diffs ......
Feel your teeth chatter after that ..... Haha !
SUPAN;1095347 said:
Hi seniors ...
RBB, Rear differential also got mount Fuji?
Just changed my engine and gearbox mounts today. 160,000km. And BOY! I wished I had done it sooner!! It's now super smooth like what a BMW should be all over again! When I first collected by my car, I already felt the difference the moment I pushed the engine start button.
I was so used to the old vibrations. And at the first traffic light I stopped at, the engine was so smooth and quiet that I had to check my tachometer as I thought my engine had stalled!!
Bought from ES - engine mounts @ $42 per piece, and gearbox mounts @ $14 per piece. Replacement labour not included.
Old car feels new again! =)
