Can M5 Style166 Rims fit on the F10 ?
aerosports
Hi Bros,
Does anyone know if the M5 rims on the E60 would be able to fit onto the F10 ? Thanks for the advice.
Re: Can M5 Style166 Rims fit on the F10 ?
Mayb some1 on this forum is resourceful enuf to get the offset. I tried on a German website. Got wheelsize but no offset.
Offset numbers not out yet on realoem.
Thanks bro for the responses. You mean the offset for F10 rims are not out yet ? What do I need to ask to find out about the F10 rims to check on fitment ?
likely the offset will not be suitable. notice that for each new model they introduce the offset becomes more and more aggressive. from the 5 series to the 3 series, new models always have a more -ve offset. saw a E90 using E46 rims, fit is can fit, but super sunken in. look like push cart.
fit will most prob fit... though specs arent out yet... at most will look sunken...
then again its the M5 rims..which should be more aggresive than the ordinary E60 rims... shud be ok i guess... lets see when the specs are out
It is amazing you guys can actually advise without any figures.
Even if you can assume same PCD at 120mm, but you cannot assume same (a) offset and (b) centre bore diameter.
looking frm the past changes... like E65 to F01... centre bore stays the same...
offsets changes frm E39 models to E60 models are close as well... there might be changes to the new F10.. but i guess not untill it wont fit...
i presume it will work... even if it doesnt it should need spacers.. centre bore and PCD should stay the same... bmw hasnt changed it for the F01 dont think will do any for the F10
Great news, I have set of the m166 and am really looking forward to seein them on my new F10 :))))..love those rims !
if canot fit... just lelong here.... confirm can sell....
last time my M166 wheels sell more than i bought... steady ar... its super high demand
Yup, agree with Terry.....it'll more or less same as E60.....
'The Great White'
What are the offset numbers?
kenntona;530460 said:
What are the numbers?
Dun need any numbers lah....
Just buy DPE from you, any offset & widths also can.
Dun need to worry about his worry about that......haiz............
'The Great White'
Even then, also need to know the specs !!! Wahahahahaha............
Else all advising like blind experts.
As usual.....ACS always comes out rims for new BMW dam fast....
Brand new: AC Schnitzer Type VIII Wheels for the new BMW 5 series (F10):
BMW 5-series (F10) with AC Schnitzer Type VIII wheels
AC Schnitzer Type VIII Wheels, BiColor
front:
8,5J x 19" offset 27 with tyres 245/40 R 19
rear:
8,5J x 19" offset 23 with tyres 245/40 R 19
front:
rear:
9,5J x 19" offset 33 with tyres 275/35 R 19
Can take reference from them...........kekekekekeke
'The Great White'
if the above offfsets from ACS is correct for the car then the current E60s will be too protruding for the F10!
That's why must buy DPE!!
Original M5 166 rims front offset is +12 rear is +28
Replica M5 166 rims have less aggressive offsets.......usually either +38 for E46.......
kekekeke
'The Great White'
unless the ACS boys are recommending spacers i suppose....
Which was the case in the older Type 2 and Type 3 days, not sure about latter models.....
But that inherently again means there is no number to work with !!!
