can anyone help tell me what this alignment report means pls..
xiaofoggy
as above. just sent for alignment. can anyone help decipher frm the report if things look normal on my car. and also my apologies that the image is horizontal. I cant figure out how to rotate it. tks in advance
Re: can anyone help tell me what this alignment report means pls..
Looks quite symmetrical....why align in the first place ?
cause recently changed tyres and the first shop did a pretty bad alignment job. car felt rly wobbly at 110kmph and was pulling heavily to one side.....
That is more with balancing the wheels......
edit - actually if pulling one side then need to check alignment .....
Someone told me if steering turn left or right itself, alignment maybe wrong.. Have to go back to AD for new car to rectify. Is it true?
No issue, good alignment. Did you do it at kian teong auto?
This printout is same as Kian Teong. Maybe i should go align mine as well together with balancing.
yup I went to kian teong.. car feels straight n planted. but steering still steers slight left after 2.5 lampposts. heard pml says itz normal hahah
May be you can double check ur car bushes. Btw how big is ur wheels?
car bushes just chaned too.. running 19" staggered. heard its normal to pull though
E90? Numbers look alright, though front camber very conservative. Front can dial up to -2 degrees from current neutral.
if not alignment or bushes, which means it's ur tyres and tyre pressure...which brand...? Never encountered any pulling feel when driving.....my car tyre pressure- 19" 36 psi fr and 40 psi rr conti 5p--- 20" 37 psi fr and 42 psi rr pss
im gettting the same left pull too =(
Bro im using Goodyear f2.. 19'' 39psi front and 38psi rear. is there any recommendation on the psi?
Bro can u elaborate abit on what u mean by conservative, and what is the difference if i go -2 degrees. newbie here.. thanks in advnace..
More aggressive means you can cup corners better.
hoho.. i think i should go back to ask them already..... dunno why they put so conservative for me,
if you are using 235/35/19 front, the pressure too high...anyway if you are going back to them, ask them to check the pressure for you...and notify them about the pulling thingy...they are quite helpful...
Nothing wrong being conservative. Mike could have asked you whether you drive hard, and if the answer is no, he will not set aggressive offsets for your front.
Many people explained the steering veer phenom in many ways - some blamed the roads, some suggested that our rides are never symmetrically weighted (left-right) in the first place...... fact is, the best solutions are still in the alignment numbers in camber, toe and caster.
If it is a tyre pressure/uneven wear issue, get Mike to scrutinise it. Might have to bring down to tyre shop for a check.
If it is a hardware issue, it is more problematic. Gotta check steering components (such as tie rods, rack and pinion, column couplings) on your next servicing.
