camber correction bolt for E36
peterlaw
hi,
anyone has the above installed in your car? the camber of my car's front axle, a E36 318IS is not equal and the car has tendency to pull to the side with the more positive camber. is there an aftermarket camber bolt (a camber plate will be too costly for my application) that can be used?
peter
if the stock camber correction is maxed out already then you'll have no choice but to add shims to your system and try to even out both sides. thats the only way.
Camber for our car is more of less fixed but u can still do minor adjustment by adjusting the bolt position at the strut tower.
unless there is something wrong with the control arm / suspension, the car should not have positive camber
i when to PML and found out that there is a camber correction bolt for my car. ordered a set and will post results after the bolts have been installed.
