freedom;826272 said:dear brothers, i was at the meet up and someone mentioned that the screeching can be solved by changing brake pads. can someone recommend me which brake pads are good? 8)
thanks!
ben1;826567 said:Just go PML or MA to get it changed under warranty lah!
thanks!
ivanttp;849990 said:my brake pad also worn out, brake and release brake after engaging hand brake will have the screeching sound too...
going to bring to the workshop to change (under 2nd hand car dealer's tab as the warning came up just 1.5 weeks after purchase). shall report back findings after the change![]()
jinooi;826785 said:dude, you might think that they changed your pads and rotors - that's what they told you.
did you physically see the old ones being changed out and the ones installed are new? i'm almost sure your answer is no...
what they most probably did was take a drive out of the workshop to try to bed-in your brakes, which they couldn't have done properly given the time and the road conditions. the temporary 'bedding-in' will last you at most a couple of weeks, or until the top layer wears off. the most conservatively you drive, the faster it will wear out...
what you need to do is to bed-in your brakes periodically. else they will still squeal no matter how many times you bring it to PML or MA.
Red_Bean_Bun;850607 said:And how did you know that they did not ? And bedding in is not the solution to all squealing brake problems .....
Ah yang;850849 said:Bro,juz brake harder can liao lah. Mine also like tat. Bt after some hard braking ok liao. If again then brake hard again. Whether got sound or wat also nvm,s long it can bring u 2 a stop safely can already.
nighthawkcity;850853 said:i found that it occurs during initial drive.. like the morning or evening when i just go back to the car after 10 hours work..
BimmerHead;850868 said:I think so...this morining drive out carpark ...I hear it at first two junction...then no more..
ivanttp;850545 said:Changed my brake pad for my E87. Now all working fine![]()
