BMW Z4 - EPS Steering issue
Ale_72
New Member
As many other owners, I'm experiencing the usual issue on the EPS related to high temperatures (>35° degrees).
The steering is not smooth.
I knew that BMW raised an unofficial bulletin that should address this issue.
The bulletin can be found on the BMW TIS (versions >2005).
I was not able to get it.
Now, anyone of you could check on TIS (if possible) for this path?
Documents --> SI Technical --> 32 steering --> Document TSB 3220104
BMW Italy stealer, of course, will not provide it to me :(
Many thanks again.
