BMW F30
ROYYY
can anyone suggest which one should i get 316i vs 318i? Also, their common issue.. afterall should i get F30 316 or 318? I am currently E92 325 owner. Thanks~
After testing between a 2013 316i and a 2016 318i at Kampong Arang, I decide to get the 318i instead. Overall the 318i is smoother and nicer to drive. The depreciation currently is surprisingly lower for the 318i. When the 316i reaches 7 years and above, you will get a hefty bill for the engine repair as the N13 is known to have broken plastic guide rails in the engine, as seen in numerous pictures here.
318i - at least it is LCI model.........unless you prefer 4cyc then 316i...as 318i (3cyc)
both rides using the same 8-speed gearbox so pretty smooth...
*** Happy shopping...
cheeeeeeeeeeeeeeeeeeeeers
seems like 316i isnt a good choice. alright might consider 318i. thanks for the information!
alright i think i will consider for 318i instead. thanks for the information!
Would u consider the N20 engine? 320i or 328i
