Advice needed on warranty
teamip
Hi fellow members,
I just bought a second hand E60 and the car is two week bofore warranty ends. Wat are the parts i should request to change or wat can i request to change under the warranty programme and how should i go about doing it. Please advice. Greatly appreciated
Re: Advice needed on warranty
The squeaky door sills; the squeaky wipers would be a good start. Simply tell them its a problem.
hi mark thanks so much for your reply but i notice the car does not come with a sill which u r refering to. The transparent sill on all the doors rights? and can i request for a shock absorber change?
is wiper under warranty as well? i learn something new each day :)
Sorry mate, I meant door rubber seals. And regarding the shock absorber, are your tyres pitted as in uneven wear? If mileage is still low, then you have a good case.
if i'm not wrong wipers and door seals would be considered under wear and tear, unless they were just replaced and gave you problems.
3rd yr warranty is PML so don't expect it to be easy to get stuff replaced without some evidence. Wouldn't shocks to be under W&T as well?
