10 Tips to Get Your Car Ready for Summer
Infratint Automotive Film
Trusted Sponsor
Summer is waving! You might already have prepared a list of your to-do months before the summer season arrives. Some have probably taken their work out session in the gym or at home seriously just to get that summer-ready body. But what about your car? How sure are you that your vehicle can get you to your desired destination this summer without experiencing a sudden breakdown?
It is important to note that the summer heat can be hard on your vehicle. Heat can expand the air in the tires that can cause your cooling system to work harder, as the harsh sun can speed up wear on hoses and drive belts. That making sure your car runs at peak performance can guarantee a hassle-free summer road trip or getaway.
Here are some tips that you should take note of before taking your car off the driveway.
1. Check your air conditioning system
Driving under the broad sunlight can really be challenging as you will have to deal with the pesky heat. In times like this, your air conditioning system plays a vital role. Since you will be going to need the air conditioner more during the summer than on colder months, it would be better to have it checked by your mechanic before going on a road trip.
2. Make sure your coolant system works properly
Overheating of your car’s engine is the product of poor coolant system. The coolant system keeps your engine and radiator cool by circulating a mixture of water and coolant. Once you miss checking the condition of your coolant system, your car’s engine has a high tendency of overheating, which is probably the last thing that you would want to experience. In order to avoid getting stuck on the side of the road, under the scorching summer heat, it is necessary to periodically check the level, condition, and concentration of the coolant system.
3. Have your battery inspected before going any distance
Did you know that the battery of your car often fails with the sudden changes from hot to cold weather? During the summer, the liquid that the battery contains tends to evaporate, which causes the average 5-7 lifespan of the batter to shorten during the hot season. If your car’s battery is more than a few years old, it would be a great idea to have it checked at your trusted auto repair shop to see whether it needs to be replaced in the near future.
4. Change oil regularly
Your oil needs to be changed every 3,000 miles or according to the specifications of your car’s manufacturer. One of the secrets to keeping your car on its tip-top condition is to make sure that it has good clean oil lubricating its engine. In addition, keeping everything lubricated and cooled can extend the life of your car’s engine.
5. Ensure tight seal of your gas cap
Make sure the radiator cap has a tight seal. Why is it important you may ask? In case you don’t know but an ill-fitting gas cap can cause trouble with your vehicle’s emissions control system.
6. Make sure every tire (including the spare one) is on top condition
Without tires, it is impossible for your car to take you to your preferred destination, which is why making sure that every tire of your car is on its top condition is a must. If your car runs about every 5,000 miles, it important to check the tire pressure once a month. It is better to have them checked before driving for any distance. Check the sidewalls for cuts and nicks; make sure the tires are not bald yet. Also, don’t miss to check your spare tire. It is important to be sure that the extra tire you carry inside your car is in good condition just in case one of your working tires suddenly deflates.
7. Check your brake system
Checking the brakes is one of the secrets to avoid accidents. So, if you notice pulsations, grabbing, noises, or longer stopping distance while driving, it would be a better idea to have your brake system inspected. In addition, make it a habit to check your brake fluid; pay attention, especially once you notice the fluid becomes dark.
8. Inspect all lights
This is a must most especially if you will be driving at night. If you notice a burned-out bulb, better have it replaced immediately. In addition, make sure that the lenses are free from dirt and insects.
9. Don’t ignore the windshield wipers
Not because it’s summer doesn’t mean you don’t have to pay attention to your windshield wipers. There are times that though summer may be hot it can still bring pours. And having worn wiper blades can be seriously ineffective even on light rain, which is why getting a new one or having your windshield wipers repaired is an absolute must.
10. Invest in car solar film!
Driving on a scorching heat not only endangers your skin but your car's interior as well. It is a known fact that overexposure to sunlight can cause skin problems and the primary culprit to the wear and tear of the valuables inside your car. That is why car tinting in Singapore has become a necessity over the years. Not only because it gives an ultimate car UV protection but also due to the fact that it helps in maintaining a comfortable temperature inside the car.
Interested in getting your car tinted? Infratint can provide you quotations about the automotive film in Singapore! Reach us through our customer care hotline 6684 5330 or 9456 0888.
