WTS: WeissLicht LED H8 Angel Eye Bulbs Version 4
berntham
Updated 19th morning : reserved for testing... Thanks!
Fits H8, selling for S$80, less than a year old. Recently sold my LUX Version 3 to one of the bros here.
And just changed to DTEC v7 from E92 lighting.
PM me for fast deal, i will deliver but WILL NOT INSTALL :p
http://www.bimmian.com/WeissLicht-LED-Halo-Upgrade-Kit-for-BMW-E92-or-E93-3-Series
here's a run down of the 3 i've used and are using.
Lux Version 3: most expensive of the 3, least bright.
VERY HARD to install on a E92/93.
Weisslicht Version 4: least expensive of the 3, (flickers at engine start, and dims a teeny weeny bit when using parking lights),
slightly brighter than Lux version 3. Much easier to install than Lux version 3 in E92/3.
DTEC V7: 2nd in cost of the 3. so called brightest of the 3. does not flicker nor dim in any situation.
Quite hard to install in E92/3.
When i say "brighter", i am talking about a difference that's so slight, you'd have to squat there for a minute to tell.
So in reality, the "best deal" IMHO, is the weisslicht one.
So take advantage of my butt itch, changing so many H8 angel eye bulbs and get this one at a steal :)
thanks for reading!
Re: WTS: WeissLicht LED H8 Angel Eye Bulbs Version 4
You could get rid of the flickers at startup by disabling the cold bulb checks for the Weisslicht AEs ....
Bro, I am interested. Pls call me at 90466806.
WeissLicht LED Halo Upgrade Kit For E92/E93 - BMW 3 Series Coupe and M3 - 2007-2013 From bimmian.com
thanks for reading!
BUMP 4u mate!
oso hav weisslicht installed in my de-moddin e82monster.
How do you disable the cold bulb check?
Does this work on e90 318 halogen bro
hey bro how're you...
yea i did that for the front signals and could not get the right setting for AEs and Reverse lights (which i changed to Lux as well)
anyway, it's not a big issue... just a little funky at first :-D
as long as it's a H8 bulb there, which WAS USED FOR ANGEL EYES, it should be ok.
Why i say that is if you try putting an LED bulb into an H8 foglight for example, it will keep flickering...
theory is there's a different power requirment...
iwinclub5679
