WTS: Used E90 & E36 Bilstein Coilover
Status
Not open for further replies.
BMWFANS
Banned.
as the above stated i have two sets of coil up for sale,
1) Bilstein pss9 for E36 , used for 3months , SOLD
2) Bilstein pss B12 for E90 , $1200
interested can pm me.
Re: WTS: Used E90 & E36 Bilstein Coilover
sorry bro, i have decided to back out the reserved B12 at $1250. Do not call or PM me. Any issues pls communicate publicly via this channel.
Thanks
1) Bilstein pss9 for E36 , used for 3months , $1500
2) Bilstein pss B12 for E90 , $1250
For your info, B12 is not PSS!
BILSTEIN
006922 BILSTEIN - B12 Tuning Kit Gas Pressure,
Conditions see certificates Fitting Position Front Axle, Lowering 40 mm,
To axle load 1020 kg Fitting Position Rear Axle, Lowering 20 mm,
To axle load 1200 kg
006923 BILSTEIN - B14 PSS Threaded Suspension (height adjustable) Gas Pressure,
Conditions see certificates Fitting Position Front Axle, Lowering 30-50 mm,
To axle load 1020 kg Fitting Position Rear Axle, Lowering 30-50 mm,
008608 BILSTEIN - B16 PSS10 Threaded Suspension (height adjustable), Mechanically adjustable shock strength, Mounted Adjustable Gas Pressure,
008262 BILSTEIN - B16 Ride Control Threaded Suspension (height adjustable), Electronically adjustable shock strength, Mounted Adjustable Gas Pressure,
'The Great White'
:yikess:
Teacher is giving free lesson!!!
Thank you.
BMWFANS;514219 said:
$1200 for the E90 bilstein B12 ,pm if want.
Hi Andy!!
Heard from BMW Malaysia Club that you are very well known there!
Steady man!!
'The Great White'
Status
