Dre
Selling my 1yr 3mths JIC coilover system with Front 10kg & Rear 14kg springrates & pillowball top mount with adjustable camber. Also only included with my set are special custom Thrust sheets for the front struts which I had sourced seperately from the set. Read more about Thrust Sheets below.
CROSS Competition coilover systems for the High Performance BMW. The Competition Series is the top of the line coilover system. It features a lightweight design with a 15 way dampening adjustable monotube damper. With its high strength and durability, the Competition Series insures that it will last through any type of driving condition. The front damper features a 40 mm piston and the rear has either a 40 or 45mm piston depending on application. The ride height adjustability is independent from the spring perch so adjusting ride height does not compromise the spring rate or rebound and compression of the damper. All coilover systems come with a cool bend linear spring that offer last precision steering and handling. Spring rates are also custom tailored to each system and driver's preference. All Competition Series coilovers include front camber adjustable pillow ball upper mounts and most rear includes pillow ball mounts depending on application. Larger luxury vehicles have a softer damper for a sporty luxury feel and also allowing a lower ride height. Based off of racing technology, the Competition Series Coilover is a street performance suspension, customizable for full track use.
PILLOW BALL UPPER MOUNTS: Included for some vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems. Some applications may come with a rubber bushing uppermount.
COOL BEND LINEAR SPRING: Linear rate spring manufactured using chrome silicon metal alloy with a cool bend process to prevent sag or loss of spring rate. Each kit comes with various spring rates that are available for more of a custom set up.
HIGH STRENGTH INVERTED MONTOTUBE: This unique design features a 40mm piston with a one of a kind bumpstop design incased inside th damper. The walls of the shock casing is lined with crase so that the absorber body can easily move along inside the shock casing body. There are also two thrust bearings to protect the absorber body.
HELPER SPRING: This set of coilovers come with helper springs to aid in streetability of the coilovers. Also allows for a wider range of higher spring rates and for a smoother ride.
ADJUSTABLE DAMPENING: Available for all applications with 15 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec.
DURABLE MONOTUBE DESIGN: High pressure nitrogen gas filled monotube design with special stable viscosity index oil that will not be affected by wide temperature changes. Therefore, heat does not affect the performance capabilities. 40mm and 45mm pistons are used on certain applications.
ADJUSTABLE LOWER BRACKET: More durable than factory brackets with adjustable ride height ranging from 0.5" to 2.5" drop without sacrificing the suspension travel. Made of either high grade steel or high strength aluminum
*EXCLUSIVE!* CUSTOM THRUST SHEETS: Thrust sheets provide a variety of benefits to coilover systems. As a spring becomes compressed the coils attempt to distribute the energy by unwinding. This is called twisted force. The unwinding makes the spring rate irregular. By allowing the spring to smoothly rotate around the perch during compression, the spring rate will return to normal. Thrust sheets also help dampening and rebound of struts too. Thrust sheet's bearing action allowing the rotation of a spring allow the load on the spring to be more evenly Distributed which reduces lateral shock shaft load. Increased lateral load on shock shafts cause a reduction in the struts ability to rely on valves for dampening force.
Price $2,200 for the set. Labour costs to install are seperate. PLS SMS 9843-1011 Andre
