WTS: 17" style 236 with Tires
Blazer
SOLD Thank you for your interest.
RIM and tires taken off new F10 with 300km.
RIM: 8x17 225/55R17 ET 30 No scratch, perfect condition
Tires : Pirelli Cinturato P7 Run Flat 225/55 R17 97Y Made in Europe
Price: Similar rim in shop asking $1000. Will sell for half. New tires selling for over $500 each at agent. Will sell for half.
If you want the complete set, pay for the tire and I will throw in the rims for $200. Don't like to haggle on price. So, I publish the rock bottom price here swee swee liao.
Stock with workshop in Tampines, they can provide balancing and installation for $50 only.
If you want to confirm if the rim fit your ride, do some homework here Felgen-Katalog - BMW-Treff - der Treffpunkt fr alle BMW-Fans und -Fahrer Alloy Wheel Offset Technical Help - Offset or ET diagrams and text information to help you understand alloy wheels offset
Re: WTS: 17" style 236 with Tires
Did some research for a bro. Rim will fit E60 5 series. Tire has a small problem.
e60 5 series calls for ET20. My rim is ET30, which means the trim will pushed 10mm outwards, a desired change to make the car look more "wide track" but don't attempt to push out too much as it will compromise the car stability and mechanical performance.
Tire is a problem because specification for 17" rim on E60 calls for 45 tire height. My is one size up at 55. The size diff will cause the speedometer to be 7% "slower". Meaning, when you are at 100kmh, actual speed is 107kmh. It will not be a problem if you don't mind this "inaccuracy". You can always change back to 45 height on next tire change. Nevertheless, if you have lowered your car, larger tire may rub the fender.
ok365ok365com
