Windshield condensed due cold air from dashtop vents
jimmy631
I have this situation on my E90 PFL... Everytime I turn on the aircon in circulation mode or any other mode, my front windshield will condense on the outside at the middle part. I feel cold air blowing from the dash center top vent. I tried to press different modes to see if I can stop the cold air from coming out from that top vents, but to no avail.
Am I doing it correctly, or is something not working right on my car? Anyone got this problem, and how can I fix it?
Re: Windshield condensed due cold air from dashtop vents
condensation outside the windscreen occurs when the interior is much cooler than the outside.
mine has this issue on some nights too. but only when I have one of the four front facing vent is closed.
couple of ways to go around this,
1) air con temp adjust higher. mine is always at 23deg.
2) fan speed set to auto then change to front blowing mode only. there was an informative post previously about this setting from R2d, search for it.
I have tried all the above steps to no avail... Meantime I will stick to previous thread of using sponge to block the vents.
Did nothing at all. It was like this all along.
Go to a WS and check the chassis type selected for your ride's IHK module.
what is IHK module?
remove your wind screen....ta dah!
Can I ask for my f10, when I turn on the front aircon with dehumidifier, is it sop posed to blow hot or cold air.
at 22deg and above, warm air will also starts blowing at your feet ( original design for winter climate)
Also having sponge may not be a good thing, after too much direct sunlight,
the sponge starts to disintegrate and get into the airconditioning system and
u may end up having early x mas effect
Have your tried those anti-fog applications? Might help if you still can't find the cause.
