Whistling Sound when accelerating
astrosky
Dear Bros
Anyone can advise me on a brand of intake which gives a whistling sound when accelerating?
Thanks
Re: Whistling Sound when accelerating
err... you heard whistling sound when accelerating in someone else's car?
can mean 2 things - either there's a leak in the exhaust system. not a good thing, happened to me before...
or the car is supercharged or turbocharged. whistling sound is the sound of the charger spooling up. very good thing, has not happened to me, yet...
astrosky;347634 said:
Dear Bros
Thanks
Whistling sound... hmmm
Are you looking for the *whistle* that comes from Turbocharged cars?
If so, that's usually from the Blow Off Valve. The *whistle* is from excessive pressurised air being expunged. Usually to protect the turbine.
Stock BOVs usually don't have such a sound. HKS SSQVs give you the sharpest whistle.
So... if you want the whistle.
Lup a turbo. Replace the stock dump valve w/ a HKS SSQV. :D
think he's referring to the whistling that can be heard in the car during accelerating.
the BOV sounds like 'bung pui' sound only when changing gears right?
ok, mebbe not farting sound, more like 'pssshhht'...
Half correct there.
Whilst most/all BOVs have the same purpose. (dumping excess pressurised air)
The Sound they emit depends on the brand/design
Some BOVs go...
- "Psssssshhht!" (like a fluttery fart)
Other BOVs go....
- "Zzzzzuuui!" (like a whistle)
It happens not during the gear changes. nor during acceleration..
But whenever the turbo has started spooling
And the foot is let off the accelerator.
:D
oh dear, means for my car...cant get the whistle liao. Sian...haha
I don't have BOVs but last night when I was gunning my Kokoro down a little, there was some whistling... Very soft, very light...
hear hear, the true colours being revealed... after initial running in of engine...
more to come... kekeke...
nickname for her car...
also the name of one of the characters in dead or alive 4 (DOA 4).
not to be mixed up with FP, who does not look the least bit like kokoro :yummie:
are you charged? otherwise better check with other e90 drivers to see whether they have the same prob.
mine was e36. after it was fixed, much better...
i think yapster secretly force inducted his car. No wonder so fast
I get that whistling sound too leh.
But its real soft..
And i dont think it can be heard frm outside the car.
I believe u must be talking bout BOVs.
Wrx la.. Evo la...
I know why already. I only difference with my car was the air filter... It's prob the "sucking in" sound... Or so someone told me...
Yes. that's most likely.
With an aftermarket air filter, there will be a small "vacuum-like" sound from the front of your car. It becomes much more pronounced if you use an open pod.
It's a little more subtle, compared to the BOV whistle.
And that happens during acceleration. As the Air Intake gulps in air.
jas, your whistle is from the turbo, if it is subtle, then you need to press the go pedal harder
for that E90, is it wind noise from the mirrors, is it radio interference?
my filter doesnt whistle, it ROARS
i have no idea who would do it in Singapore.
big operation mate, engine out, new pistons, new valve springs, loads of stuff
