Where to get White bulb for rear number Plate?
KITT
Anyone out there can tell me where to get "white bulb" for my E90 rear number plate?
PM me if you have info on where to get it? How much? Name of the product?
Thanks a million...... :nehnehhh:
Re: Where to get White bulb for rear number Plate?
Kitt,
U can try McWell over at ubi...Make sure u got the right voltage one hor...:)
else, autbacs at bt batok :)
actually ah.... if can find the strip or led lights and put above ur number plate....hmmm.. quite nice wor.....
Is it true that these white light bulbs blow easily even with same voltage?
Do you know what is the product brand? Does the cost include free installation?
Thanks
kitt..got the below from Paya ubi Mcwell accessories shop las yr.
u will need to buy 2 bulbs, jus ask the guy to use a screwdriver to insert into the slot next to the translucent plastic casing & pull it out.
They will Install free for you.
This is as bright as the normal yellow bulbs? Or are they dimmer? i have been on white LEDs for a while back then.. but the blubs keep on blowing and i think its a hassle to keep changing them. They dont come cheap too..
its brighter than the stock.
las yr when we changed & mths later 2 guys experienced one of the bulbs blowed. Mine still working fine till now.
If wrong voltage, sure to melt. Even if the transparent cover that u can see doesnt melt, the inside will. Dont know whether can find white bulbs which have the same voltage but do be careful. You can also try PinLiang opposite Zouk.
FiftyFive;172748 said:
Adrian... any melting of the plastic??
the E46's rear number plate bulb placement is close to the plastic cover compare to E90 & tat may explain why it melts.
Hmm this shop sell at $12++ too?
Is this something like this?
Website selling this Xenon White LED License Plate Lights
$17 US for a pair..
These hyperwhite LED Bulbs replace your dingy yellow license plate bulbs to set your car off! YoCan Anyone provide a picture of the package and result if possible thanks!
Call 9796 0266.
Wif installation:- White Bulbs $20 per pair
LEDs $30 per pair
